Question about Kitchen Ranges
Range door won't open after error 41
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 06, 2012
  • Fran Nov 06, 2012
    Siemens Gas Range with threeD Surround Convection HG2528UC. I was able to get the door open by starting the self-cleaning again and then quickly canceling it. I still can't get past the error 41 when I try to do the self-cleaning.
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: oven door on gas range won't open. Apparently
Hello & Welcome to FixYa
This is a common problem that occurs when self-clean cycle is used after a long time or when the oven gets old. Recommended repair is replacing the door latch-lock assembly as the latch mechanism cannot be repaired. Please get back to me if you have any other questions.
Kevin
Posted on Jul 18, 2011
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
The range oven door won't open
If this happened after self clean then your safety fuse in the back is tripped.
Feb 06, 2013 | Kitchen Ranges
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
My frigidaire affinity ATF8000FS2 went thru the wash cycle but won't spin. Error Code is 41. How do I fix it. The washer is only 1.5 years old and is used maybe once or twice a week. I hope this is...
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Washing Machines
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
Jul 18, 2011 | Amana ACF4225AS Electric Kitchen Range
Bosch convection oven in self clean mode, am getting an error code of 41
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Jan 24, 2010 | Bosch Evolution Pro-Style 700 HDS7282U...
Bosch evolution range door won't lock for sef cleaning
You are correct. If the door does not lock, the self-clean function will not activate.
Spray some WD40 into the lock mechanism and let it sit over night. Then try it again.
Feb 10, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
