Question about Water Pik Waterpik& Elements& Handheld Showerhead
Hot and cold water in shower comes out in a triclkle
I have one turn knob in the shower. When I turn it to the right for cold water, the cold water comes out fine - good pressure. When I turn it to the left to mix the cold with the hot, the water goes down to a messy, low pressure type of trickle. What is the problem, can I fix it myself, and how would I do that? I really don't have any plumbing experience.
  • cannet Jan 07, 2009
    Thank you. This is very specific, so it should easy to follow. Will comment again after I give this a try!
    Genius:
  • 1,605 Answers
Shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Posted on Jan 07, 2009
I'm not sure what brands my faucet or handles are.
You can remove the center (Diverter valve) without turning water off, Will need deep well socket. Check the o rings and or washers and replace or take valve to Home depot to match with new. If you can't find one there go to local plumbing supply or ace. I turn hot then cold on and off real Quick while the valve is out just to clear anything that might be in lines. stand to the side or you will get wet! You might want to get new hot and cold valves while your at it just make sure to turn off water at meter before you remove them.
Jun 06, 2017 | Home
Electronic ignition hot water heater (6gal) lights but wont get water hot. The red light inside my RV goes off and back on after about 3 minutes. When I checked the unit outside, the pilot is lt, but not...
check to see if setiment has settled on the pilot....blow it out with air if it has. This issue comes up often with water heaters and rv refers. If that is not the problem and the pilot remains lit, but never increases when the thermostat is turned up, you probably need a new gas valve/thermostat.
Feb 26, 2014 | Jayco RVs
Can't take a bath!
The diverter can become clogged with mineral deposits. The handle will have to be removed to gain access to the diverter. The diverter can then be disassembled as necessary to determine what needs to be done to free it up.
Jan 17, 2014 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
My shower ok for mins, then cold, then after 5 min too hot
replace your mixet stem it is located behind the knob where you adjust your hot and cold water you will have to turn your water main off then you will need a flat head screw driver a phillips screw driver a pair of needlenose pliars to pull it apart
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water switch need some time to turn on
Sounds like the switch inside is not making good contact or it didn't have a good seal to protect it from water. I would have a proffesional come and look at it and check out the switch. I'm pretty sure it is still under warranty if you just had it installed a few months ago.
Mar 22, 2009 | Home
Water Pik Waterpik& Elements& Handheld Showerhead  Logo
391 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
