Question about McCulloch Electrical Supplies
I have a McCulloch Model# FG6000MK, 11 HP, generator that stopped producing electricity while it was under a load. after checking it over, it looks like it has blown the diodes. OM gives a p/n of 7204-EG6001 for the diodes. I have tried to order at OEM mfg site but they say that the part number is bad/ out dated and none in stock. Where can I order the diodes??
2 Suggested Answers
  • 142 Answers
SOURCE: McCulloch Generator model FG6000mk 11hp run good
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Posted on Jun 14, 2010
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Nov 24, 2014 | Electrical Supplies
Stop making power too the plugs
Check to make sure the capacitor is not burned out. It is usally under a cover on the back of the generator
Mar 21, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
I have a Mcculloch 5700 watt Generator that needs carburetor rebuilt and can't seem to find parts. Any suggestions on where to get parts ?
Take the make and model #s to a lawnmower shop, they can get what you need, if they do not have it in stock. Also remember to check in tank strainer for restriction.
Mar 04, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
We have a McCulloch 2300 Generator. It runs, but no electrical output. What should I look for ? Glenn
look for a reset button, either on the generator or on the dash with the recepticals. my 5700 has fuses there also
Jan 03, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch Generator model FG6000mk 11hp run good until I turn on generator then stop running do you think the generator bad and can it be rebuild ?
Try this link:
Jun 12, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
My fg6000mk 11 horse had valve break and ruined the head. where do i get parts
I am pretty sure that is a Honday 11 Hp engine. The part number for the head is
030730Q01F000 (CYLINDER HEAD ASSEMBLY)
Most lawn mower parts supply places can have your part in hand in a couple of days. I was not able to find a price for the head but I know they are not cheap.
When you call or visit the lawn mower parts store make sure you have the engine model number with you. They amy even ask for a serial number. The numbers are near the oil drain plug toward the bottom of the crankcase but under the starter.
Let your fingers do the walking on the phone first... you could drive about for sometime before finding the shop that can help you. (i.e yellow pages Lawn mower repair)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
98 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
