Question about Kenmore Elite 20972
My Kenmore 20972 Top Load washer stopped working after I washed up some bedding. It shut down after I did a few loads of laundry and wouldn't drain. Finally got it to drain. Now it won't work at all. Go to turn it on and it just makes a loud humming noise.
  • 15,935 Answers
It appears your drive belt/coupling or main controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
The spin cycle will not work. Any suggestions?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 15, 2011 | Kenmore Elite 20972
Kenmore Model 22722 will not drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
My top loading kenmore elite washer model #20972
No, this is probably a direct drive that has a faulty plastic coupling from motor to transmission. Go to:
http://www.fixya.com/support/r385252-replacing_motor_coupling_W... by jsrock516
Please give him a pat on the back for the help.
Oct 12, 2009 | Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Kenmore 90 Series is NOT DRAINING or AGITATING
motor to transmission coupling or transmission itself.
Jul 02, 2009 | Kenmore 23822 Top Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer overheats and shuts off
It sounds like you have a bad timer. Your timer is basically a wheel that turn and opens and closes sets of contacts. Once these contacts go bad, they stick together. Your machine will basicall try to do a few things at once and over heat (hence the reason it works after it cools back down). A replacement timer should be availible from both your local appliance parts supplier and from the manufactures web site.
May 29, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
