Question about JVC KD PDR40 Radio / CD / MP-3 Player KD-PDR40
Jvc kd pdr40 radio won't take in the cds. it ejects the cds every time I insert the cd.
I try inserting them forcefully but that doesn't work either. the radio just ejects it.
SOURCE: Unable to play MP3 CDs on JVC KD-G140
I had this same problem and realized after reading the manual that this model does not play mp3's. They use the same manual for the g140 and the g240 (the model which plays mp3s).
Posted on Jul 09, 2008
VOTIT
  • 2071 Answers
SOURCE: How do Iset time on
go to the setting button and press hold for 15 seconds ,and if the number in the screen is flashing,its the time you set the hour ,the minute and the date ,that's all...
hope may help you;
dont forget to rate;
Posted on Jul 18, 2008
  • 55 Answers
SOURCE: jvc kd-sh55 head unit
Have you tried pressing the "RESET" button on the stereo? I have a JVC unit in my car and the reset button is a tiny hole behind the detachable face. Take a pencil or a pen and insert the end into the tiny hole an hold for a few seconds. This will reset the stereo and you should be able to eject the CD as you normally would. If it's a mini-disc (8mm) you probably would have to take the unit apart and manually retrieve it - big hassle. Check the owner's manual to find out where the "RESET" button is if it is not behind the face. If you don't have the owner's manual, you can download one from jvc.com.. Hope this helps.
Posted on Aug 30, 2008
  • 83 Answers
SOURCE: I have a JVC cd
Is this an original music CD or songs copied onto a blank CD?
Posted on Sep 18, 2008
  • 7 Answers
SOURCE: JVC KD-G396 wont Play any cd or mp3 PLEASE HELP
take it back
Posted on Dec 14, 2008
Jvc kd hdrc60 please eject disc
CD mechanism probably needs service.
Feb 22, 2012 | JVC Car Audio & Video
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
MY UNIT WONT PLAY CD'S
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Not reading MP3 cds
Have you tried removing the negative terminal from your car battery and giving it a few minutes. Hook the terminal back up and try your cd player again? That should be the same as resetting your cd player settings.
http://instrukcje.elektroda.net/caud/jvc/KD-G501.pdf
Sounds like you have a problem with the mp3 format being used.
Apr 19, 2008 | JVC KD-G501 CD Player
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
JVC KD PDR40 Radio / CD / MP-3 Player KD-PDR40 Logo
19 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
