Question about Cuisinart CPT-140 Cool Touch 4-Slice Toaster
4 slice toaster
My toaster is only 7 months old, and the main lever on it does not stay down. (the lever on the right side that is to be used for toasting only one or two slices.)
  • 4 more comments
  • rustface Jan 13, 2008
    Same problem. I submitted an online product support form at cuisinart.com.
    I opened up the unit. My ohm meter showed some issue around the large gray resister/capicitor and/or the little "catch" that seems to have an electromagnet in it.
  • Anonymous Jun 14, 2008
    What else can it be
  • lindamartz Aug 16, 2008
    I have the same problem exactly. The control for the toast on the right side(the side which is supposed to be used first) will not stay down. The toaster is too large to stay on my counter for only a two slot toaster so I would like to find a way to fix it.
  • Anonymous Mar 20, 2014
    When I turn the timer on to start the toaster, it trips the fuse and knocks out the other sockets. Any ideas what this could be ?
  • Anonymous Mar 30, 2014
    Proctor Silex Cool Touch 4 slice toaster. Model 24415 series A4279
    4 slice toaster only one side locks
  • 883 Answers
Open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
SOURCE:
Lever will not stay down
There is a catch thatvis not free to move in place when pushed down. It may be jammed.
Feb 12, 2013 | Cuisinart CPT-70 Classic Style 2-Slice...
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
I just bought this kenmore 2 slice toaster and the toast lever won't stay down!?
Make sure it is set dark enough. Some toasters will not stay down if they are set too light.
Feb 11, 2010 | Kenmore 135101 2-Slice Toaster
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Feb 23, 2007 | Kenmore KTES4 4-Slice Toaster
Cuisinart CPT-140 Cool Touch 4-Slice Toaster Logo
735 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Irene Tulloch
Tom Chichester
Steve Allison
Steve Allison
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
