Question about Apple iPhone4 4G iPhone 4
Iphone tough to unlock is not working
When i slide to unlock on screen there is not working, like stuck there
Try powering off and then on again, then slide to unlock.
Good luck.
BL.
Posted on Nov 05, 2012
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
Hello, My Iphone's slide to unlock screen
you might need to calibrate the touch screen, it should be an option to do it in the menu.
Dec 04, 2009 | Apple iPhone Smartphone
Iphone 2g stuck at slide to unlock screen
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Jun 18, 2017 | BoxWave Corporation Apple iPhone 2G...
I dropped my iphone and now the unlock slide doesnt work
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
its not a hardware problem brothe as i am also facing same problem...actually it all happen with jailbreaked iphone...ad i'hv checked its deep root directory there an application called "lockdown" is the main cause of that...nd still there is no crack of that.....
two days back i unlocked my iphone 2g it was working properly before that i was facing the same issue as you are facing....but now again it went to the same problem....
i hav a temp solution of that...
use blackra1n u can find it from blackra1n.com
nd for few seconds slide to unlock will work
or u can use it by connecting it with ur itunes ...connect usb wire nd slide it again nd again...u can unlock it..bue its just temp
Feb 04, 2009 | Computers & Internet
IPhone touch screen not working
I have the same exact problem. I dropped mine, and it landed half on concrete, half on a piece of foam board, and when I got to shut mine off, it will slide to power off, but will not slide to do anything else. Everything works perfectly fine, people calling me, texting me, nothing is broken or cracked, I can't even unlock mine, it's stuck and it's making me very upset! I want an answer as to what I can do and or can't do.
Jan 28, 2009 | Apple iPhone Smartphone
I have an iphone that does this at times too! I have to reboot it periodicly, seems more often when I use it a lot. I have found several issues with winterboard and plugins for it to cause some of my problems. might try changing your screen to normal and see if it still acts this way.
Dec 20, 2008 | Apple iPhone Smartphone
Apple iPhone4 4G iPhone 4 Logo
96 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
