Drums squeaks not rubber seal rubbing only 3 months old
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
That actually sounds like a bearing. If it is new, I would use the warranty.
Posted on Nov 05, 2012
3 Suggested Answers
beltronic205
  • 1461 Answers
SOURCE: The drum seems to run crooked and rubs...
You can buy new drum Spider which has bearing fitted check cost 1st...
Posted on Nov 17, 2009
caroldon
  • 17129 Answers
SOURCE: machine makes banging sounds and the spin barrel
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Please check the play of the bearings and also the main door seal gasket.
Posted on Jul 18, 2011
Small grey rubber bits
could be a problem with the seal as it is only 3 months old call who you bought it off and have it looked at under the year warrantee
Mar 15, 2014 | Washing Machines
Turning left or right the steering wheel on my 2003 Camry LE sedan squeaks (or rubs). Looking for the perfect mechanid
In most cases, the squeaking is caused by the steering column where it goes through the firewall, there is a rubber dust seal where the shaft goes through. Try to lubricate the shaft where it makes contact by pushing the rubber boot back a little then applying a clear silicon grease or silicon spray to the area of contact. If you do need to replace your steering shaft this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/steering-shaft.html
Aug 04, 2013 | Vehicle Parts & Accessories
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
Why is my coleman mach squeaking
Our AC did this and needed bearings replaced. Cost $10 dollars to fix it. Husband did the work. Took him less than an hour to replace the bearings.
Jul 10, 2012 | Coleman Mach III Air Conditioner
I have a squeaking noise sounds like coming from the driverside rear tire.I put new brakes & drums on it . Then a hub bearing after that i see the support bearing was wipe out i had that change &...
get some armor-all in a spray bottle. spray some on the bushings where the arms swing up and down, then spray some on the tops of the struts if there is a bellows where the spring can rub against the rubber.
Jul 14, 2011 | 2006 Saturn Vue
Toyota manual windows..very sticky..
The 'sticky' windows can be caused by:
1) Dead windows seals rubber that are no longer flexible and can break down to the point of being sticky rubber: replace the seals or as a temporary solution rub a bar of wet soap on the seals where the windows slide against.
2) Lack of lubrication in the windows winder mechanism: you will need to remove the doors handles & internal covering panel to get to the gears located in the doors cavity where the windows slide in.
Hope it helps!
Jan 27, 2010 | 2004 Infiniti G35 Sport Coupe
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
Sep 23, 2009 | Electrolux AWF 1435 Front Load Washer
Squeak from the back end.
but hoping I could get a little help.I get a very loud squeak from what seems to be the back end of the bike under power. I don't notice it in first gear but 2nd and up I hear the squeak that is very loud. It is not a constant squeak but a jumpy one that seems to match the engine vibrations (as in it seems to squeak every time a cylinder fires) but only under power.I just put on new rubber on the back end last night and I left every guard off and it didn't change assuming that I have guards rubbing and squeaking but apparently not the case.Now what I find to be very interesting is that it is not always there. Case in point: Almost a month ago, I got caught in a pretty good rain storm. It didn't squeak again until I washed it. After I washed the bike, it never really went away until I ride for a while. Oh yeah, almost forgot to mention that the squeaking never really stays for a whole ride, just the start of it (10-20 minutes?)Is this a symptom of the wheel bearings going or do I have a problem with my belt drive? The bike is a 2003 XB9R and I know that there have been problems with the belt on some (not being strong enough) but from what I can tell, the belt looks imaculate for being 5 years old.Any ideas before I start throwing money at it until it gets figured out?,1. the belt will not squeak, so it's not that. 2. this is hard to figure out online.3. is it while riding constant or during normal/hard acceleration?,,,
Nov 10, 2008 | 2005 Buell Firebolt XB9R
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
