Question about Whirlpool Refrigerators
I own a whirlpool refrigerator model G15FVAXB 01. The front of the freezer keeps icing up regardless of the temperature setting. What can I do?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
That model number comes up as a deep freezer. If it is icing up near the door only it is a gasket leaking air into the freezer.
Posted on Nov 05, 2012
fridgetech
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
woodchuck789
  • 4066 Answers
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 02, 2009
How long should it take to make ice in a brand new whirlpool refrigerator?
It will depend upon how warm it is, how warm the water to the icemaker is, and how much food is in the freezer. Regardless, I would say within 24 hours you should have ice.
Aug 24, 2014 | Whirlpool Refrigerators
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
Mar 23, 2011 | Bosch Appliances 20.19 cu. ft....
Freezer has stopped freezing items regardless of what temp you select, and lower fridge gets cold only enough for drinks. Motor continually runs as though it is trying to reach the required temperature...
can be a thermostat issue, or your condenser in the back of the freezer may be plugged up with ice. Unplug the fridge and take the back freezer wall off, be careful not to pull on the wires connected. It may be full of ice. Don't chip at the ice as you may hit a refrigerant line and cause a leak. You can speed up the process with a hair dryer, being careful not to melt the plastic. If this is frozen, you may need a new defrost heater.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool refrigerator model#WRT-75680. Have
Assuming the freezer is adequately cool, it sounds like the freezer fan is not running. This fan transfers chilled air to the refrigerator section. The fan should be located behind an access plate in the freezer. If it's running, you should be able to hear it. If you can't hear it, remove the access plate and look at it. If it's not turning, you will need to replace the fan motor.
Oct 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge works only on the max setting
needs a defrost heater, keeps it from freezing up. my friends did the same thing, she changed defrost heater and works fine now.
Oct 29, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Temperature control
hiya
the thermostat should be inside the fridge compartment usually near the light.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
