Question about Tools & Hardware - Others
Need new throttle valve
Black & Decker air dual action orbital sander Model 6174, Type I , made in Japan 1977, 78; air throttle valve which is rubber, has disintegrated (Part No 702-465) I am wondering what other companies used this Japanese unit? Where can I find a replacement valve to fit? B&D says the part is obsolete. What can I use to dissolve and clean up the old valve?
  • Pete B.
    Pete B. Jun 28, 2015
    Does anyone have a manual for this Black & Decker air dual action orbital sander Model 6174, Type I?
    Top Expert:
  • 14,162 Answers
I just looked on ebay you can buy the orbital sanders for as low as $10.00 Even the Black and Decker is around $ 15.00 Cheaper to replace than to keep. Good Luck https://www.youtube.com/watch?v=Ff8iYu7JXvA
Posted on Jun 28, 2015
comax
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
  • 384 Answers
SOURCE: orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Posted on Jun 12, 2009
  • 226 Answers
SOURCE: black and decker model 7404 1/3 sheet sander - not orbiting
I read elsewhere of someone using JB Weld to fill in the pentagonal hole in the bottom plate, after coating the armature of the motor with a light coating of oil to keep the JP Weld from sticking. Assemble, and set aside for the JB Weld to set up.
tom
Posted on Jul 13, 2010
SOURCE: how do you change paper
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Posted on Dec 04, 2010
SOURCE: need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Posted on May 12, 2011
Sander won't shut off
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Mar 17, 2014 | Ingersoll Rand 311a Air Dual Action Quiet...
Black & decker 7448 sander sounds & smells like motor ceased up. only makes a humming noise & feels hot.
could have had a bearing problem that caused the motor to cease up, It might be time for a new one unless you are handy, if so I suggest going to dewaltservicenet.com and downloading a breakdown for the tool and make note of how you disassemble it to find the problem, If it is the armature or field it might cost less to replace it.
Oct 23, 2011 | Black & Decker 7448 1/3 Sheet Orbital...
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Black and decker model 7404 1/3 sheet sander - not orbiting
wear inhibitor part number 86355 has broken on you. When this part brakes it brakes into tiny pieces which then leave the case so it hard to tell whats wrong. They don't make this part any more as the 7404 was discontinued in October 1975. I hoped this helped. I have the same problem.
Feb 07, 2009 | Black & Decker 7448 1/3 Sheet Orbital...
Tools & Hardware - Others Logo
125 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
