Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My sony kdl46hx800 wont turn on - Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
    Top Expert:
  • Sony Master
  • 14,553 Answers
Much like saying my car will not start----If total dead look for the fuse---if not able to open set etc consider having a technician look at the set and get an estimate for repair.
Posted on Nov 05, 2012
How can sony bravia kdl50 be repaired?
It is irreparable. If the screen is broken, it should be replaced. Contact the authorized service center for Sony.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Sony KDL46HX800 46 in. 3D LCD TV
How to fix a Sony Bravia KDL-46HX800 cracked screen with compatiple screen
You need a original replace screen, the compatible screen may not work.
Jun 27, 2014 | Sony KDL46HX800 46 in. 3D LCD TV
I have sony kdl-46hx800.When I turn on tv it work for 10 min. than cuts off by its self after that red light blinks 7 times.
7-blinks of standby light to Sony LCD TVs, indicates a fault to its power supply board. An over-voltage shut down. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony KDL46HX800 46 in. 3D LCD TV
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
When i try to use Internet with my sony XBR-55HX925 tv, it displays: error de red 1106...Plase, what can I do for solving this problem ? Thank you so much.
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection:
  1. Check the Network Connection.
    1. Using the supplied remote, press the Home or Menu button.
    2. Select Network Setup .
    3. Select View Network Status .
    4. Select Check Connection .
    If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection.
    Follow these steps, if the error continues to appear:
  2. Unplug the TV and wait 60 seconds.
  3. Power on and off all of the networking equipment, including the modem and router.
  4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer.
  5. If the issue continues, wait and try viewing the content later.
Aug 14, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
HOW TO GET 5.1 CHANNEL OUTPUT FROM TV
you need to use the optical out on the tv and also a surround sound amp with optical input. that's it. easy.
Feb 04, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
Hi, I have a Bose Lifestyle 8 systesm, a Sony PS3 and a Sony KDL46HX800 3D LED LCD TV. I want to run the sound through the Bose speakers. What is the best way to connect the devices this? Also,...
Use this cable http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA
the 3 connectors for the video will go to the tv (you will not see any difference in the quality of the image compared to an HDMI, it's a very good quality cable) and the 2 audio ones to the Bose. You will probably need a audio RCA extension cable to reach the Bose - a $15 cable, thick enough, will be just fine.
No , there is no difference, unless of course you buy the absolute cheapest $5 cable. A $15 to 20 cable will give you the exact same image as a $150 to 200 one.
Dec 19, 2010 | Televison & Video
KDL-46V3000 no picture when I turned it on. can lamp be replaced?
You do not have an individual lamp in your lcd set. If you have no picture it is probably the inverter that is bad. I would take it in to a service center and have it diagnose professionally.
Dec 10, 2010 | Sony KDL46HX800 46 in. 3D LCD TV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
