Question about Panasonic Lumix DMC-TZ3 Digital Camera
The automatic lens cover on my Panasonic TZ3 doesn't fully open or close.
    Novelist:
  • 172 Answers
See my solution to this common problem on other questions from those with same problem.
Posted on Feb 27, 2009
Foldable lens cover doesn' t open and closed fully... Thanks.
It's usually merely a grain of sand or dust jamming it. But it's also usually easy to fix. This link outlines repair techniques for a stuck automatic lens cover. Recommend trying the less "risky" ones first before considering the end of the lens.
Dec 27, 2010 | Canon PowerShot A610 Digital Camera
Kid opened the lens while it was off
The tacking has came off zoom and mostly likely broke the plastic pins inside Panasonic will repair it for $50
Aug 05, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens won't come out
If the camera is powering on as indicated by a normal screen, you can sometimes coax out the lens by rapping the camera against the heal of your other hand, or a hard surface covered with a cushion, like a double with towel.
The idea is to try to free it up without damaging the camers. This problem is common on cameras if dropped or have a few years on them. It is even more common for the Lens Cover on the TZ3 to behave this way. If it is the plastic lens cover that won't open, you can coax it open with a toothpick and if it closes again, I would just carefully pull this plastic cover right out and as a manual plastic cover that will fit the lense.
In any case, it is getting dated by the TZ5, so an alternate is to sell the defectic TZ3 on Ebay and buy a newer TZ5, new or used, on ebay to replace it. Reparmen buy popular cameras like the TZ3 to fix and resell them. If you have everything that came with it, including the box, it is probably worth $40 as is.
Dec 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic tz3 cover gets stuck
Common problem with TZ3. You can try to lub lens cover using graphite lub. Use it sparingly and after lens works, wipe off excess with dust cloth. Be sure not to get any on lens itself.
If lub doesn't work, you can pull out the lens cover altogether and find a manual lens cap the will fit.
The other option is to sell it on ebay to a repairman in a auction and replace it with another working used ones. Keep your accessories and by a used one cheap without accessories.
Nov 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Lens Won´t Open
This is a common problem with TZ3s. Power the camera on, then puff a little graphite onto the lens cover and coax it open with a tooth pic. Do this, powering the camera on/off till lens opens normally. Add little more graphite if necessary, but sparingly.
Graphite is used because it is extremely slippery, but will not attract dust like an oil will. At the same time, it is black! so you don't want to use anymore than absolutely necessary make lens work. Even then, check to be sure lens itself is clean after, and wipe carefully with an Eyeglass lens cloth only if necessary.
Another option in to remove the lens cover altogether by just pulling the leafs out of the camera. Another option is to sell your working but lens cover problem to a repairman on ebay, and buy a good TZ3 or TZ5 on ebay used, refurbished or new. Good prices if you bide your time.
Don't put in your best bid to the very last minute of the auction. In the mean time, put a camera you are interested in on your MyEbay Watch list and set a reminder alarm on your cell phone about 5 minutes before the auction is to close, then if the price is still good, enter your best bid 30 seconds before the end of the auction. Refresh the auction page on your PC to keep track of the bidding right up to the last 30 minutes so you can see the last remain bid and if it is worth outbidding on this camera. Again, if you are not in a hurry and bide your time, you can get a great buy. There are plenty of these cameras sold every day.
Jul 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic lumix 5.0
The TZ3 has a design problem with their new automatic lens cover, ie, manual lense cap on TZ1 was illiminated on TZ3.
Make sure your lense cover is completely retracted in front of the lense. If not, nudge it fully opened and see if this solves you problem. If it does, contact Panasonic with your problem. If not under warranty, tell them you want them to fix 'their' problem on your camers. Google it on the net and see how common this problem is.
Apr 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Refurbished Panasonic Lumix DMC-TZ3
lens cover does not open or close fully. any suggestions?
Jan 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
235 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
