Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Pump blocked error - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
Have you check the pump and drain line for blockage?
Posted on Nov 06, 2012
  • sherimathis
    sherimathis Nov 08, 2012
    Yes, the problem was in the flywheel on the pump. Had to clear out a ton of fibers which cleared up the problem.
  • Richard Roth
    Richard Roth Nov 08, 2012
    Thanks for using FixYa!
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
WHAT DOES "OE" MEAN WHEN DISPLAYED AFTER WASH IS COMPLETE.?
An Error code OE on The LG washing machines simply means the pump is blocked.
Presumably the water isn't being emptied properly you might have something blocking the pump.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out.
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose near the sink waste or somewhere else in the system etc.
Sep 13, 2015 | Washing Machines
Spin cycle isnt working.."OE" is pn display
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
My machine is showing OE
Well that easy....OE means output error.....possibly a blocked pump check the pump trap filter.....possibly blocked.... when was the last time you cleaned it out???? PEOPLE NEVER DO. good luck with your 'output error' Tony the technician down under.
Apr 02, 2011 | Washing Machines
Came up with fault code 37 on the screen and wont spin whats wrong with it?
Fault Code 37 is "Pump Blocked Error" which means for some reason the machine did not drain properly. This can be due to a blockage in the pump such as a lint ball or wire from a bra that got down in the pump, perhaps a safety pin, etc. It also can be caused by objects that get past the pump but become caught inside the diverter valve, which is downstream from the pump. One other thing to be aware of, and this trips people up sometimes- a pump that is failing ELECTRICALLY can also cause the same error. If the pump is overheating and shutting down, the machine will not drain and the control will properly sense that there is still water in the tub. I've suggested in the past that this error be renamed "pump error" because the term "blocked" makes people look for an absolute condition.
Feb 09, 2011 | Fisher and Paykel IWL12 Top Load Washer
My LG Washing machine WM2496HSM is displaying and OE error. From my research on the internet it appears the pump is blocked. Can you assist me to locate the pump? Regards
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | LG WM2496H Front Load
Code37
Error code 37 means you have Pump Block Error.Now there are 4 reasons the machine will have this error--1---Your pump is jammed and will not drain the water.--2-- Your drain hose is kinked or blocked .--3--The pump or wiring to the pump is faulty.--4--Your motor controller is faulty.Now where is your pump draining to? Is it draining into the laundry sink or to a grey water hose.Please reply with answer about where it is draining to and I can help you further.
Jun 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
309 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
