Question about Watches
Battery pluged in to back of watch do we pull out ??
    Top Expert:
  • Watches Master
  • 14,553 Answers
If not sure take to a watch shop or even Walmart and let them do it--not very expensive and better safe than sorry.
Posted on Nov 05, 2012
How do i change a lego watch battery?
I used this website How to Pry off Watch Backing Without Proper Tools all you need is a small screwdriver. There is a tiny tab on the back of the watch you must pry off gently, then you will probably need same screwdriver to get the battery out, again, gently There is no need to pull out the knob on the side of the watch or take off the timer ring from the face. Once you replace the battery, the back snaps back on fairly easily.
We had a c3p0 watch and the battery is an sr626sw which you must source online.
Jan 23, 2014 | Lego Star Wars Darth Vader Wrist Watch for...
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
I opened the package and dont know how to turn it on!
mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
Jun 17, 2011 | Watches
The watch was a gift. The watch has not run since I got it. There is no tab to pull to activate the battery. How do I activate it? How do I open the back without damaging it to replace the battery,...
Have a professional do it so you don't scratch the back. Often the back has to be put on with a press. When customers put in their own battery, the gasket is generally gone or cut, the cell is incorrect or they cannot get the back on or they scratch the coil and the watch repair is substantially more.
Barrows Jewelers, 2015 Glendale Ave. Toledo, Ohio 43614
Mar 29, 2011 | Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
Jul 15, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Sector 900 watch #2651901025 I try to adjust the time of my watch I pull up the button then pull it back but the watch stop working
If the battery inside is more than a year old have it change for about $8 at any watch or jewelry shop.
Apr 12, 2010 | Watches
How do i set time back and have watch work again
This model has a pull out crown (the middle "button") on the side of your watch. Simply pull the crown out and turn to set the time. If your watch is not working after this then it likely needs a battery change.
Nov 03, 2009 | Bulova 96R19 Wrist Watch
I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
Jan 14, 2009 | Bulova Watch
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
