Question about Whirlpool GSC25C4Ey Side by Side Refrigerator
Items freeze on top shelf of refrigerator. All temps are per factory specs.
Items freezing on top shelf of refrigerator
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Posted on Nov 05, 2012
Testimonial: "Thank you--I'll proceed based on your info. It sounds logical!"
rpbuice
  • 161 Answers
SOURCE: Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Posted on Dec 16, 2008
thompsonds20
  • 53 Answers
SOURCE: items freeze in back section of refrigerator
Your freezer is partially chocked and blocked that's why it is not cooling in all the coils. You must flush out the refrigerent and flush out the dirt and moisure from the system and recharge the refrigerent and the unit will work normal. Do not forget to change the drier to avoid repetition of the same complaint
Posted on Jul 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: ed22pwxxn00 setting on 3 top shelf items freeze.
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Posted on Aug 29, 2009
aasc
  • 1606 Answers
SOURCE: items freezing in the refrigerator
Due to the ice on the vent ( damper ) , the damper is probably frozen open , so it will not close , causing the refrig section to keep on getting colder . Put your hand over the vent and feel the air being circulated . Use a hair dryer on the vent for a time and ocassionally feel the vent to see if the vent closes stopping the air flow .
Posted on Aug 01, 2010
heatman101
  • 43501 Answers
SOURCE: Our Whirlpool GI5FSAXVY refrigerator is
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Jan 13, 2011
Jenn air side by side, refrigerator side is freezing items at 2 on a 1 to 7 scale, how to I fix it?
Thermostat may be off a little but 1 coldest and 7 warmest? Cheap fix be to adjust thermostat and make sure damper flap isn't stuck open
Oct 24, 2016 | Refrigerators
Milk freezing
Need more information, but try turning the fridge to normal and the freezer the same. Try placing those items in another location. Problem could be a bad air damper.
May 10, 2015 | Frigidaire FGHS2631PP Gallery 26 Cu. Ft....
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
heatman101
Jan 22, 2011 | Refrigerators
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Items freezing in the refrigerator
Aug 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frig has cold spots that can freeze some items
If you can get the brand name and correct model number, I will be able to get this fixed for you. But if the vent ducts leading to the refrigerator bottom are not responding to manual adjustment. Cold air tends to migrate down to bottom of refrigerator, because it's heavier air. Look for correct make/brand and model number and we will fix this. Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Fridge keeps freezing thing
HI thanks for your question. the factory setting is ok. try to adjust the other setting to a higher# try this give it some time to adjust and set the other to a lower# thanks
Oct 15, 2008 | Frigidaire FRS23R4A Side by Side...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Whirlpool GSC25C4Ey Side by Side Refrigerator Logo
1,033 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
