SOURCE: Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
SOURCE: Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
SOURCE: need manuel for maytag stacked washer/dryer unit model lsg7806aae
go to this link and download the manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSE7806A&siteCd=MT_EN_US
SOURCE: REPLACE BELT
Hi there ,
how do I get the belt around the drum ? do I have to take the whole back panel off the dryer ?
Don
I recommend that you will post your question under
the correct category (washing machines) and maybe add more details to it, so it will
be easier for Experts to understand the question and answer it.
You can also contact the site directly at: http://www.maytag.com/contact-us/
