Question about Canon PIXMA® MP530 All-In-One Printer
Cartridge jammed Pixma MP 130. Printer not hooked up to computer and still I get a warning "cartridge jammed". I have cleaned the head; removed the color cartridges and head and replaced all. Turned printer on and off; removed power cord for several minutes. Tried without success to print a nozzle display. Still "cartridge jam". Help please
    President:
  • 2,110 Answers
So here it goes: Open the cover as if you would change the cartridge. Then press the little black button I highlighted in the picture. Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on.
Posted on Jan 04, 2009
My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
E2 = Reload the paper correctly and press [Black] or [Color]
E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [Black] or [Color].
E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP 160 IS PRINTING ONLY BLACK AND PINK COLLORS
Maintenance your cartridge with head clean or deep clean. If you don't get full colour, then change the colour cartridge.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA mp 150 printer error msg reads E3 or paper jammed
it is the problem caetyridge adjust cartridge part no 40=41,830=831 or cartridge nozel is fill extra ink clean it not software open your cartridge and clean cloth
Jul 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer says put in cartridge
oh the joys of an hp. get some rubbing alcohol and a q-tip, clean the brass connection points on the catridge with alcohol, also, clean the brass connectors that are in the slot where the cartridge goes. Make sure to let them dry good and try again. We have an hp at work and we are always having to do this.
Jun 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
"Wrong Cartridge" Message is being displayed on the Canon MP 780
Remove the print head and cartridges.Unplug machine for 30 min.
Repower and reseat head and ink do a head alignment.
If this does not correct it may require service.
Ink Cartridges are the BCI6 and 3 series correct?
If using CLI8's and they are flashing red you have a bad cartridge or it is in the wrong location.If so Canon will replace the bad cartridge.
Jun 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge jammed
EUREKA! At least the following worked for me w/ this piece of sshhhh.....
went to menu - user data - cleaning..after the "cleaning' whatever that is...it worked. I also took out the cartridges and cleaned the ink contacts. hope it works out
Jan 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge jammed
my canon pixma mp 130 says it has a cartridge jammed...Ive tried new cartridges but still get the same situation
Aug 17, 2008 | Office Equipment & Supplies
Canon PIXMA® MP530 All-In-One Printer Logo
129 people viewed this question
old marine
old marine
