Question about Sharp AQUOS LC-22SB28UT 22" LCD TV
Where to plug outlet into tv
Where to plug the outlet for tv into back of tv
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Look carefully----most are in recessed socket-----a few are up pointing down in the recess near the sides or the av jacks.
Posted on Nov 05, 2012
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
My tv has a problem staying on and sometimes it turns it self off and turns it self back on and has become more frequent with turning it self off
Another thing to try is plug a different device into that same electrical outlet and see if it turns on/off as well. If that device also turns on/off by itself, it could be a faulty outlet.
Mar 09, 2011 | Samsung SlimFit TX-S3082WH 30" TV
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Had the digital cable box installed yesterday. The tv worked
The cable box has an AC outlet on the back of it and sometimes the installer plugs the TV power cord into it. This outlet has two modes--IE: on all the time or switched. If the outlet happens to be programmed to the switched mode, the cable box has to be on before you can turn on the TV. If the outlet is on all the time, then you can turn the TV on at will. So, you have to decide if the TV is plugged in there or it is plugged into the wall recptacle. If none of this explanation fits, then we need more information.
Jan 07, 2009 | Hitachi 46UX24B/25K 46" Rear Projection...
Sharp AQUOS LC-22SB28UT 22" LCD TV Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
