What channel does this rca have to be on for cable
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Most if using a box have to be on channel 3 or in rare cases 4. The box may also have a switch that selects which channel the set has to be on.
Posted on Nov 05, 2012
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
Dec 16, 2013 | Blaupunkt Car Audio & Video
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
A channel does not work
could be an issue with the radio, an rca cable or inside the amp itself. swap the rca cables around to see if the channel not working works and the channel that worked before doesnt work. if this is the case, it's an issue with the rca cable or the radio. i'd suggest replacing the rca cables first in this situation.
Feb 17, 2010 | Kicker KX800.2 Car Audio Amplifier
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Can't View Cable RCA f32444
You will have to go in the menu and switch it to cable mode, then do an autoprogram and you will have all the channels.
Sep 04, 2007 | RCA F32444 32" TV
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
