I have a LG 47lh30 (bought in 2009) and I just moved. After moving and hooking up the TV it began experiencing issues. Once turned on the top about 4 or 5 inches loads the pictures from top to bottom
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 43 Answers
Not exactly sure, but I have had related issues ( I'm an electrician) it is possible the wall outlet's polarity my be switched (hot and neutral reversed) hot is the short slot on receptacle. The best way to check is get a receptacle tester at Lowe's , home depot, etc there not expensive and easy to use if it reads open ground is not a big deal and shouldn't be the cause of ur problem, many home do not have grounds but should be utilized when possible. Good luck
Posted on Nov 05, 2012
  • Jon Yetter Nov 05, 2012
    Thanks, I just tried moving it from a power strip to straight in the wall and that helped, but now the bottom 3/4's of the screen have colored vertical lines. Thanks again for the reply!
SOURCE: Vertical line on TV
usualy this problem is cause by the lcd drive board.
Posted on Oct 24, 2007
SOURCE: Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Posted on Jan 07, 2008
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
  • 11 Answers
SOURCE: horizontal half black screen, sound is still there
A plasma screen uses thousands of tiny fluorescent bulbs in different colours (red blue and green) to produce a picture. Just like standard house hold fluro lamps, these tiny bulbs use starters to turn them on and off. As there are so many bulbs in the panel and therefore starters, the panel has a number of "starter controllers". These controllers can control anywhere from a quarter up to half of the screen. If a controller dies, it takes out it's segment of the screen. Unfortunately, it sounds as if this is what has happened in the case of your LG - this is also common in NEC and Fujitsu panels. Althought these controllers can be fixed, it usually takes more time and money than it's worth- unless you have it under warranty in which case the manufacturer will just replace it. Sorry top be the bearer of bad news. hope it helps
Posted on Jul 06, 2009
LG 47LH30 47 is on then it turn itsself off automaticly
This is a power supply regualtor board problem. Check its. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 05, 2013 | LG 47LH30 47 in. LCD HDTV
Bottom 3/4 of LCD Tv screen vertical lines
John sometimes electrical wires being in the wall or cords laying behind a tv can interfere with antennas, cable, or sat tv cables try to put a little distance between them that's all I got best of luck
Nov 05, 2012 | LG 47LH30 47 in. LCD HDTV
Lg 47lh30 when first turned on the picture flashes off and on but still has sound.It does it for a couple of minutes then it goes back to normal.
This problems are those 2 long boards call the LCD inverter boards.There one long LCD inverter board on the left,one long LCD inverter board on the right.These 2 long LCD inverter boards are having problems and the causes.It providing a backlight to the LCD screen panel to get a picture.When ur tv are finally have only a few flashes of picture and died for good have sound only left.Those 2 long LCD inverter boards are the causes.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 01, 2010 | LG 47LH30 47 in. LCD HDTV
Hi there I have just purchased a LG LX9500. This is a great TV, wow. But I am experiencing one issue. When subjects are moving or being panned across the picture appears "ribbed" or another way to...
trumotion on or off.. try adjusting the blur and judder setting in the picture menu...
banding is common on this set during panning scenes, but it sound like you are descibing trumotion artifacts.
Sep 15, 2010 | LG Televison & Video
Lg47lh30 having audio sync issues while viewing upper channels in hd mode. Is there a firm ware upgrade?
There are firmware updates for that issue. However, some lip-sync issues not because of the TV. They are caused by the cable/satellite box and or a home theater amplified speaker setup.
I can help you find your firmware version by using only an LG remote. You will need a pen and paper before you start.
1. Turn the TV on.
2. Select the menu button to go into your TV menu.
3. Now move the highlight to the Toolbox but do NOT select it.
4. Now push the #7 on the remote seven times and wait.
A display will come up and show you your Firmware information.
5. ****Do not power off the TV. You have to use the Exit or select Cancel to correctly get out of this Service menu.
Send me the complete Firmware information (V2.1.01) from your screen and your complete model and product code from the back of your TV(47LH30-UA.AUSJLUR).
Or you can call LG service and they can perform the updated firmware if it is needed.
May 20, 2010 | Televison & Video
Ford fussion 2010 will start no problem but once transmission gear is selected the car appears to go into gear but will not move...forward or reverse...no dash sensor lights are on
I do not know the solution. However, I experienced the same problem on a rental in Hawaii (4 cylinder 2010 Fusion) as I was attempting to pull out onto a busy highway. Also occurred several other times.
In my opinion, it is a transmission defect and a safety issue. The car had less than 8000 miles on the odometer. Return it to Ford.
Jan 31, 2010 | 2009 Ford Fusion
What is the remote control code for an lg tv. we want to program a univeral remote into an lg tv.thanks
The codes are provided with the Universal Remotes not the TV. If they don't have one listed in the set up manual for the remote control then check the manufactures web site. Please take a few moments to rate my answer... Thanks
Nov 20, 2009 | LG 47LH30 47 in. LCD HDTV
Input codes directv remote (rc64), lg 47LH30
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10856 for Lg tv
Aug 12, 2009 | Universal Remote Control DIRECTV Universal...
TV Comes on in the middle of the night
another infared device tricking the set, remote lights, sky box, video senders for sky etc.
Feb 26, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
