Question about Garden
I have a john deere d170 it only has four hours on it... it will start but runs really rough.. the it will die five to ten mins later... put a new fuel filter on it.. did not make a difference
  • 153 Answers
SOURCE: Riding lawn mower won't start
The carburetor is clogged from old fuel. remove and clean and consider getting a carb kit to give it new seals and gaskets and needle/seat. Sta-bil in the fuel, particularly over winter will prevent this problem. When the work is done, be sure to drain the old fuel and use fresh.
Posted on Jun 25, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
M2Tech1
  • 313 Answers
SOURCE: john deere 42 inch,17.5 hp-was running good then
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
Posted on Aug 13, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
Where would we get as manual for the d170 john deere grass bagger
Try this link to Deere customer support:
http://manuals.deere.com/cceomview/OMM167392_B2/Output/Index.html?tM=HO
If that's not your model, look around - they do seem to have quite a few manuals online, and offer to sell you a paper copy if they don't have an online version. Good luck!
Aug 08, 2014 | John Deere Riding Lawn Mower. D170 54 in....
John deere d170 hit rock and mower will not engage
well if you READ your owners manual its tell u how to reset it or fix it...
May 15, 2017 | John Deere Garden
Harley fxstc 1999 sputters and dies after five ten min of riding
You need to check the fuel filter -- follow the fuel line from the tank down to the filter, should be tucked in below the seat..
May 17, 2010 | 2002 Honda VT 600 CD Shadow
Oct 02, 2009 | Garden
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
