Question about Maytag MDE2600 Electric Dryer
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. any ideas?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Posted on Nov 05, 2012
shaggyrat
  • 1224 Answers
SOURCE: gas dryer
blower motor relay is bad or the dials are bad
heres a way to check the dials
turn off the gas and run the dials if at anytime the dials stick during its cycle then you know this is the fault this usually the commen issues of all dryers the dials just wear out and so parts just dont work
also check the door switch this could be an issue why it gets cold clean out all vents and filters after "every use"
Posted on Jul 07, 2008
  • 67 Answers
SOURCE: Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Posted on Oct 28, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
milten1
  • 1304 Answers
SOURCE: maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Posted on Oct 10, 2009
Testimonial: "You were very helpful and I appreciate it. It ended up being the main breaker on that line. So the landlord replaced the breakers and Bam it was fixed"
Maytag Dryer runs for 8-10 seconds then shuts off accompanied by burning smell
When you say it runs for 8 - 10 seconds, do you mean it spins for that long or the flame is lit for that long?
Dec 01, 2012 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Neptune dryer beeps a lot and does not run.
what is the model number,sounds like you have a bad computer board but the problem is alot of parts for the neptune are no longer available
Sep 16, 2017 | Maytag Dryers
Is there supposed to be a hole on the side of my dryer
Well, though it be simple, you might clean the lint filter everytime you use it. Over time a dryer even with lint filter cleaned will still collect small amounts of lint inside it. You shouldn't worry much but you could call the maytag man to come and take apart the dryer and clean the inside. <;O)
Sep 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag 5806 Gas Dryer starts and suddenly stops.
You may have a problem with a thermal overload sensor. Since it runs and then shuts off, this sounds like the problem.
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs for 20-30 seconds then turns off
Mine just did the same thing, so i took it all apart and spun the motor with my hands for a few minutes. And it began to work. I think it is just because the motor is seized let me know how you make out.
http://www.diynetwork.com/diy/ha_maint_repair/article/0,,DIY_13869_2268643,00.html
That is all I can help you with for now!
Mar 19, 2008 | Maytag HYE3657A Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Mdg4000 GAS
bad rollers could be making black dust but the real problem is the tumblers seals letting the roller dust get into the tumblers and on to you clothes.
Black or brown makers are from the faulty or damaged tumblers seals you have one in the frount and one back...
I can help you strp by step if you want to do it yourself.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDE2600 Electric Dryer Logo
217 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
