Question about Bosch Axxis+ WFR 2460 Front Load Washer
Need to remove front of washing mashine - Bosch Axxis+ WFR 2460 Front Load Washer
  • Bosch Master
  • 744 Answers
This video will show you how to take the fron of a bosch washing machine
Posted on Jul 30, 2013
Hello.i need a help,my whirlpool 6sense washing mashine 9769b when spining do horible and loud noice! I try to find bearing but i dont cnow did my washing mashine have one.
Any front-loader machine will have a shaft and two bearings supporting the tub. You may need to remove the back to find it. Also, check to make sure that whatever supports the tub (spider attached to the tub and bearing shaft) is still intact. Some models have reputations for this spider corroding and failing in as little as 2 years.
Apr 12, 2016 | Whirlpool Washing Machines
I Have a combo kenmore washer/dryer model # 417.94712400 and I need to open the washer to inspect a water leak. how do I open this washing mashine.
Remove the 2 screws at the base first
If ya run a load with the front off to look for leaks remember there are moving parts
I recently worked on a dryer portion and took these photos
Jul 25, 2011 | Washing Machines
I have a hot point washin mashine that does not finish a wash and stopes half way through then lights at front of mashine start flashin
Had this with mine. Cleaned the filter (as decribed elsewhere on this site). Also cleaned the component fto which the drain hose attaches - guess this is the pump. Just unclip the drain hose and the hose going into this pump, and check there is nothing obstructing the pump. The clips are a bit of a fiddle, you might want 2 jubilee clips to replace them. Then ran a "maintenance wash" as per manual (ie a hot wash, no clothes, no detergent). Seems OK now
Nov 02, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf 000 will wash but wont rinse or spin any suggestions please
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear....
May 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Washing mashine shows door not locked
There will be a retaining band on the inside lip of door seal, on the front of the cabinet.
Insert a small screwdriver or similar into the lip of the door seal, there you should see the band, prise it off, and then pull the seal of the front of the cabinet.
Reassemble in reverse order.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Hotpoint Washing Machines
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
My washing mashin shows F35; First shows sud
Check the drain line for kinks or obstructions first. Then check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check for anything clogging the pump and inspect the pump impeller for broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully, it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Place for washing mashine
You do not need airflow for the washing machine only the dryer.
And yes you can put it inside of a cupboard or cabinetry,as long as you have water supply, and waste water discharge access
Jan 19, 2009 | Washing Machines
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Aug 31, 2008 | Hotpoint WMA31 Front Load Washer
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Bosch Axxis+ WFR 2460 Front Load Washer Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
