Question about IBM ThinkPad T41 Notebook
Do not turns on
When I press the on button looks like is going to turn on ( not on the screen just the buttons) but then everything goes off again.
Any advice
Thanks
  • derrickneeve Jan 21, 2009
    when i press the power there is six lights to come on but only 4 come on can you help me
    Scholar:
  • 157 Answers
Check the power switch botton if it is working good..if not, try to replace the switch botton..it is commin with 4 legs..
Posted on Jan 04, 2009
  • Jorico Berongoy
    Jorico Berongoy Jan 04, 2009
    check the power switch botton if it is working good..if not, try to replace the switch botton..it is commin with 4 legs..
Will not turn on
Dear Felisha. There is more we have to know. What kind of camera are you working with--what lens are you using with it, and when did you get it?
Dec 15, 2013 | Samsung Cameras
Screen is frozen
Hold down the power button for more that five seconds to force shutdown. If it goes into sleep or standby (power light flashing slowly) the press power button to power up the press and hold power button again for more than five seconds.Power light should go off then. You can the power up again and it should be OK.
May 29, 2012 | Computers & Internet
I am new to the video world and just purchased a Canon HF S200 from a guy here locally it is used but looked to be in great condition and working properly. But less than 15 minutes after the purchase and...
Have you got the user manual? If not, you can download it from www.iusermanual.com.
I am not familiar with you videocam but the mannual shows all of the buttons and functions etc. There are what appears to be at least one critical button on the outer edge of the LCD screen itself. Perhaps this may affect its functions and be causing your problem.
Anyway, have a good look at the manual and be sure you understand the functions of the buttons.
Because everything else works OK it is most likely caused by pressing the wrong button at the wrong time. Alternatively, there may be a bad contact at the connection between LCD screen and camera.
May 31, 2011 | Cameras
My garmin does everything except it justsays locatingthe satelite, but it never goes any further all other things work sound screen etc
First make sure you are in an open area free of trees and other objects, Then turn the unit completely off and wait 30 second then turn it back on, this should now start looking for satelite again and should locate.(This usually only happens around tall buildings or inside a building or other structure such as a house)
Aug 16, 2010 | Garmin GPS
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Image screen on nikon d40 won't stay on
You have a short in your button board in your camera or a bad button board. Send into Nikon to repair. You can also look on Ebay for the part if your technical skills are up to self repair.
Jul 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Monitor keeps hibernating, can't make it stop, pixel issue.
Hey,
I think this is more of a problem on your computer instead of the monitor, ofcourse you could try another monitor and see if the same happens. I suspect your computer goes into standby or hibernation on its own, and it does work fine if you reset the computer right?
if you go into power management again, disable or turn off hibernation completely, its on one of the pages.
Make sure its not set to standby, and also disable your screen saver.
Right click on desktop - properties - then screensaver. turn it to none.
Also you could look into the computer bios and make sure its not set to standby or hibernation from there. thats unlikely but you could check.
how to get into bios.. depends on the computer, right when you turn it on, on one of the corners of the screen you will get a message, press button to enter setup or bios. press that to enter bios when its presented.
look around the bios and poweroptions.
Let me know if you need anything else.
Thanks,
Ekse
Feb 25, 2009 | Dell Dimension 8400 PC Desktop
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Hp psc 2310
unplug the power cable
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on . follow the screen ...
it shud be resolved ..
May 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
IBM ThinkPad T41 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
