Question about Fisher and Paykel Dishwashers
I have fisher and Paykel dish draw (single) and can not get the power turned on
  • Fisher and P... Master
  • 3,247 Answers
If the display is blank then that does not necessarily mean there is no power.Please check the panel located at top inside the door. If that too is blank then the controller could be faulty or the power coming to the controller could have cut off. One reason might be the heater fuse is blown. This is located within the heater element and the whole heater assembly needs to be replaced. Alternatively, the power filter is blown. This is located at the base of the dish drawer assembly under the drawer. If you are not familiar with repairing dishwashers, you will need to call the technician.
Posted on Nov 05, 2012
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
SOURCE: dish drawer leaks Fisher Paykel
When water accumulates in the bottom it triggers an error code and it keeps running. There is a water sensor in the bottom. I pull out the bottom drawer, mop up the water and use a hair dryer to dry the water (the more you mop up the less you need the hair dryer). Be careful to not get any of the plastic too hot. Kill the power before messing with the unit. The first time I did this it took 20 minutes to dry out. I have gotten more proficient and it take about 5 minutes now.
I had a water leak which was due to the rinse agent cap not being completely sealed. Water leaked out of a small hole in the front (I'm guessing an air vent but don't know for sure) and flooded the bottom.
I also had a leak due to having too tall a dish in the drawer and the top not sealing. I currently have a leak on the top drawer of unknown origin, but the bottom drawer still works.
Hope this helps.
Posted on Jul 10, 2008
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
woodchuck789
  • 4059 Answers
SOURCE: haveing a u3 code on my top draw of my fisher
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Posted on Mar 06, 2010
Testimonial: "problem solved thank you very much for the info"
  • 10 Answers
SOURCE: Top Draw on Fisher & Paykel double draw not closing
Make sure that the retaining tabs on either side of the drawer at the lower front are engaged properly. They sometimes don't positively engage and you will feel the difference when the drawer is pushed. Undo the tabs and re-engage them a couple of times to check. The drawer should run smoothly without resistance when they are engaged correctly. Check how the lower drawer moves to compare.
If the drawer is returning smoothly but feels like it's striking resistance towards the rear just before it's fully home, it's likely that the hoses are kinking/fouling behind the drawer and/or that the linkage support is broken.
If you have this older style white plastic linkage rods that hold the hoses, I would strongly recommend replacing it. It's the white plastic rod that has clamps attached to it with all the power, inlet and drainage hoses running through it.
You can get the 'retro fit linkage support' from an authorised F&P parts supplier. This is a retro fit that has specifically been designed to overcome the shortfalls of the original plastic linkage support. This consists of a metal rod and mounting plate with takes over the function of the plastic drainage support.
There are detailed instrucitons with the retro fit support which explains how to fit it. It was well under $100 when I bought one and worth the investment.
Good luck and remember always turn the power off before attempting any repairs.
Posted on Jul 10, 2010
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
Fisher and paykel dish draw not draining
If the problem is with both drawers, then most likely kitchen side drain is blocked. But if only one drawer, then need to clean filter and drain sump at base or if pump motor is not running then replace the pump rotor.
Mar 21, 2013 | Fisher and Paykel Dishwashers
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and paykel double dish draw has stopped working and is coming up with F5
Hi.
F5 is Lid Fault.
Try clearing the error code by disconnecting power from circuit breaker for five minutes. If that does not help, then there is a problem with lid switch. The part must be tested and replaced.
Regards.
Ginko
Aug 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
U 3 in red on fisher paykel single draw dishwasher
These are the cause of this fault
Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
Mar 03, 2009 | Fisher and Paykel Active Smart® E522BR...
Fisher and Paykel dish draw F2 code.
Buy a Miele they last 20 years or more and don't go brain dead in 4 years like the Fisher and Paykel
Nov 26, 2008 | Dishwashers
Fisher paykel dish draw
Turn the power off to your dishwasher for about 30 seconds by flipping off the circuit breaker in your home's breaker box. When you turn the breaker back on it will have reset the dishwasher and should begin working just fine.
Aug 24, 2008 | Dishwashers
Dishwashers Logo
93 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
