Question about Denon AVR-1803 Receiver
No video signal
Is there a fuse in the Denon
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Yes inside the unit,
Posted on Nov 05, 2012
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
Denon AVR 3806 Philips 42PFL3603D/F7 Compatibile
Make sure the control feature is disabled on both units so that they are not trying to send control signals to each other.
Secondly make sure your input is configured to hdmi for both audio and video within the receivers on screen menu The receiver usually auto senses the digital audio signal but doesn't automaticly know that it should use hdmi for video.
Dec 19, 2009 | Denon AVR-3806 Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Denon AVR-3806 keeps losing video signal. The audio signal is still good. What could be the problem?
If your using HDMI, pull it from the receiver and run directly to the TV, then run optical or digital coaxial to your receiver. It's referred to in the industry as a "Handshake" issue. It has to do with firmware and hardware of your receiver and continuous ridiculous updates from the recording industry to protect copyright. Hope this helps. If you still have issues, post a comment and I will help you troubleshoot further.
Sep 20, 2009 | Denon AVR-3806 Receiver
I have a denon avr-2807 receiver. on tv mode, i can only get analog signals. i am using an optical cable and the signal is only transmitted in digital. how can i correct this?
An optical cable is digital but its only audio not video. Are you connected to a cable or satellite box, are you using composit video, s-vid, component video, or hdmi? What kind of cable goes from your denon to your tv?
Aug 19, 2009 | Denon AVR-2807 Receiver
I have a Denon 589, PS3 and Sharp Aquos. Using HDMI cables, PS3 to TV directly = great signal. PS3 to Denon to TV= no signal.
ON PAGE 98 OF YOUR MANUAL YOU WILL SEE THE RES OF 1080P ARE NOT HANDLED SO YOU SET YOUR PS3 RES TO 1080I, 720P YOU WILL HAVE PIC FROM YOUR PS3 TO YOU DENON TO THE TV
Nov 27, 2008 | Denon AVR-3806 Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
solutiondoct
Mar 09, 2008 | Denon AVR-2807 Receiver
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Jan 15, 2008 | BenQ FP731 17" LCD Monitor
Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Sep 14, 2007 | Denon AVR-987 Receiver
Denon AVR-1803 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
