Question about Hotpoint NVL333GY Gas Dryer
Hotpoint nvl333gyoww gas dryer does not get hot. I recently has the tumbler belt changed but after that the dryer stop getting hot. I checked and changed the ignitor that's not the problem it lights up fine
5 Suggested Answers
mrfixit3667
  • 262 Answers
SOURCE: Hotpoint nvl333gyoww gas dryer heats for a few
here are a few reasons that you will get heat for a few min and then no heat.
1. if the vent is cloged, anywhere in the flexable hose to the wall or from the wall to outside. If the vent is cloged the flame in the unit will widen and the thermostat hi limit will shut she burner off untill it cools.
2. The coils for the burner could be bad and will allow the burner to light a couple of cycles and then will get hot and internaly disconect the coil untill it cools down and then will repeat and will get worse over time.
The good news :) The ignitor is good if it lights a flame, If the flame burns for more that 10 sec then the flame switch is mostlikley good. The main valve in most cases will also be good.
Im using Model # NVL333GY0WW
Posted on Jan 13, 2010
heatman101
  • 43501 Answers
SOURCE: hotpoint gas dryer will not get hot
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 03, 2010
mrfixit3667
  • 262 Answers
SOURCE: Hotpoint nvl333gyoww gas dryer's timer stopped
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Posted on Sep 02, 2010
  • 3074 Answers
SOURCE: hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
Posted on May 08, 2011
Dryer making rubbing noise like belt is weak, sprayed belt no change, tilled dryer forward noice stopped. ,also spayed with lubercate inside holes inside dryer noice stopped temporily
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 30, 2010 | Hotpoint NVL333GY Gas Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Hotpoint gas dryer will not get hot
heatman101
May 02, 2010 | Hotpoint NVL333GY Gas Dryer
Hotpoint nvl333gyoww gas dryer heats for a few minutes, then no heat. Seals appear fine, door latch appears fine, not sure what it could be - suggestions? Thanks.
Jan 13, 2010 | Hotpoint NVL333GY Gas Dryer
My crosley gas dryer is 10 yrs old. It tries to start, I can hear the buzz. Sometimes it takes hours of tries to get it to ''catch'' and turn on. I recently changed the belt and the (?)blower wheel. Any...
when it starts does it work
if once you get it started it seems to work fine
well then you have astart winding on the motor goin bad. or done.....
try this... empty the machine
tape the door switch closed
push start and try to spin the tumbler
if it starts right up you have confirmed it
your motor is done
Oct 08, 2009 | Crosley CDG6000 Gas Dryer
My Kenmore dryer doesn't work. Checked all thermal cutoff and thermostats (all closed), heat element (10.1 ohms), door switch (open circuit when door open). No intake or exhaust blockages, recently...
HAVE YOU CHECKED THE POWER COMMING TO THE DRYER / DO YOU HAVE BOTH PHASES. CHECK AT DRYER OUTLET SHOULD HAVE POWER FROM HOT TO GROUND 120 VOLTS FROM HOT TO HOT 208.220/240 OENDING ON YOUR AREA
Aug 29, 2009 | Dryers
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Feb 21, 2008 | Dryers
Changing tumbler belt on a Kenmore gas dryer
you have to unscrew the screws in the lent trap and pull up on the top piece it has platic snaps the pop up then unscrew the front two on the front piece then the tumbler will pop out thats it.
Jan 12, 2008 | Kenmore 75944 Gas Dryer
Hotpoint NVL333GY Gas Dryer Logo
41 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
