Question about Funtime FT825CR Antique Carnival-Style 8-Ounce Tabletop Hot-Oil
Noisy popcorn machine motor
We bought a used Funtime Popcorn Machine that was clean and used minimally (that's all the history I know). We have used prepared packs of popcorn/oil mixture/seasoning, and have run into problems with quick burning of kernels, the lids seem to be jammed closed (but not to touch, the popped corn doesn't seem to escape), and the motor runs with a loud whirring noise and then a screech when the pot fills to capacity. The spinner seems to rotate while we can see it, the kernels pop fully briefly before trouble starts. What can we do to fix this?
My popcorn machine made a pop sound then it lost all power. Is there a fuse in the FunTime Popcorn machine?
Have you tried any other electrical equipment in the plug? If the outlet doesn't have power it's possible that the GFCI popped in the outlet and needs to be reset. Just the first step in a troubleshooting procedure. I can't find any mention of an internal fuse on the unit.
Jan 25, 2018 | The Kitchen Appliances - Others
I'm on level 15 how do i start over on level one
Um, clean the popped popcorn out of the popcorn machine, and start with a fresh batch?
I know this doesn't help much, but it also has nothing to do with popcorn machines.
Oct 23, 2013 | Kitchen Appliances - Others
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
Can't pop popcorn
Pls check if your popcorn pack sealed tightly and kindly inspect your equipment if the radiation is enough to heat up the popcorn. You may also restart the mircowave so that you would verify if the machine does work
Jul 01, 2012 | Kitchen Appliances - Others
Old Fashion Movie Time popcorn maker
make sure the plug that goes to the heater is in properly. is it heating up?
Mar 15, 2012 | Helman Group Nostalgia CCP-515 Popcorn...
I bought a Presto Popcorn Now continuous popper at a garage sale. There were no instructions and the seller never learned how to use it, having recieved it as a "hand-down". I want to know how...
WAIT! Do not add any oil or butter. I don't know what kind of machine you have, but only POPCORN goes inside the Popcornnow. I have an old one that melts butter on the top cover, although I don't recommend that. I recommend butter in the microwave. Repeat: DO NOT ADD OIL where the popcorn goes or you will set a fire.
Jul 20, 2011 | Presto Kitchen Appliances - Others
I dont know how much oil to put in the machine can u please help me?
The Nostalgia Electrics OFP501 Old-Fashioned Movie Time Popcorn Maker is a HOT AIR POPCORN MAKER. Oil is not used in this machine.
Refer to Page 6 of the User Manual for complete instructions:
http://nostalgiaelectrics.com/manuals/OFP501.pdf
Mar 25, 2011 | Nostalgia Electrics OFP501 Old-Fashioned...
The popcorn gets stuck in the kettle until it burns
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
Jan 09, 2011 | Nostalgia Electrics Helman Group CCP-509...
Where do you buy the motor for CCP-509 popcorn machine?
I think I would look at a electric supply place for a motor like the one found in a popcorn machine. Another tip would be a resturant supply place.
Good luck on finding your motor and thanks for posting at FixYa.com
Nov 02, 2009 | Nostalgia Electrics Helman Group CCP-509...
Part for Echols popcorn machine
I Have A Echols Popcorn Popper and Would like to know how old it is the serial no. is 86P101
Feb 28, 2009 | Cretors Goldrush Popcorn Maker
Funtime FT825CR Antique Carnival-Style 8-Ounce Tabletop Hot-Oil Logo
67 people viewed this question
Top Funtime Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Funtime Kitchen Appliances - Other Expert? Answer questions, earn points and help others
