Question about Whirlpool GGW9200L Gas Dryer
Brand new dryer
WGD 9400 gas dryer won't start...only gives threee beeps. Tried holding Lock/Unlock button for 3-5 seconds.
  • 35 Answers
Try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
Posted on Jun 05, 2007
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
The Dryer says Control Locked how do I fix it
Which brand/model of dryer do you have? For most dryers, you need to press and hold either one button or a pair of buttons at the same time to toggle the lock on and off. Frequently the correct button or pair of buttons will be indicated with a small padlock or child's face. Some LG dryers are nice; the button is labeled Lock/Unlock. Press and hold the button for 3+ seconds until you hear a beep and see the alert go off. The Whirlpool Duet (and the Kenmore equivalent) require you to press and hold the End of Cycle button for 15 seconds. On at least some Frigidaire dryers, press and hold Select and Options for 10+ seconds.
The control lock prevents someone from changing the settings or starting the dryer running when it shouldn't.
If the appropriate steps for your washer fail, try unplugging the dryer for a while. If the lock remains enabled, the control panel isn't communicating properly with the board. Either the panel will need replacement or the board itself.
I hope this helps.
Jun 16, 2013 | Dryers
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
Locked status light is on.
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
Control lock button of dryer came on and now it doesn't work
To enable the control lock feature: Press and hold END OF CYCLE SIGNAL button for 3 seconds. The Lock/Unlock Control icon lights up, and a single beep tone is heard. To unlock, press and hold END OF CYCLE SIGNAL button for 3 seconds. The indicator light turns off.
Jul 15, 2009 | Dryers
Dryer says controled lock
Hold the Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Whirlpool dryer is locked control locked.
the controls on our unit can be locked by holding a button for 3-5 seconds.
look on the control panel for a "paddle lock" symbol next to one of the buttons. cant tell you which one as they do change from year to year.
just find the right button and hold it in for a few seconds. then it will beep and should unlock after that.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lock/unlock signal beeps
if you could send the serial number it will help me determine who manufactured it for sears and then point you in the right dirrection.
Sep 16, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool GGW9200L Gas Dryer Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
