I need the 3 digit code for my 74cm tv to input on a universal remote
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
What is the brand name to your TV?
Posted on Nov 05, 2012
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
professio101
  • 158 Answers
SOURCE: i have a chunghop universal remote, RM-133E and i
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
Posted on Jul 01, 2009
SOURCE: chunghop
I NEED CODES FOR SHARP REMOTE CONTROL RM-332E CHUNGHOP
Posted on Jul 02, 2009
  • 144 Answers
SOURCE: code for jvc tv with ge universal remote
Here are the GE Universal Remote 4 digit codes for a JVC TV.
0060... 0026... 0197... 0069... 0160...0247... 0923... 0012... 0065... 0067... 0141
Direct Code Entry
1. Press and hold the SETUP
indicator stays on, then
release the SETUP button.
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for 3 seconds.
Hope this helps!
Sincerely, CBR2009
Posted on Aug 01, 2009
SOURCE: 3 digit code for AKIRA tv using chunghop RM88E universal remote
code for jvc dvd
Posted on Sep 01, 2009
This is my universal remote control for the lg tv..i have tried all codes you have given but still the indicator red light blinks as i input the second number of the code.
HI NENITA, Did you try these codes--> 024, 040, 098
Setting Steps: Input Code
1.) Find out the 3-digit code for the TV that you need to control from the "Code list" In case there are several groups of codes available, please use the first group at first; in case that your TV brand has no matching code in the code list, please try the "Search For the Correct Code" mode described later.
2.) Press and hold the "Setting" button at first, then press the "Power" button. Release both buttons after the indicator light illuminates, indicating the status of code input; in case the indicator light is in other status, it indicates that it's yet to enter the code input status, and this step shall be repeated till the light illuminates.
3.) Input sequentially the 3-digit code that you have obtained. The indicator light flashes once when one digit is input. After the input of the code, the indicator light extinguishes; in case indicator light flashes twice successively, it indicates that your input is wrong and you need to input again.
Note: In case the indicator light keeps illuminating after two flashes, you only need to input the correct 3-digit code and do not repeat Step 2, otherwise Step shall be repeated for resetting.
4.) When the Indicator light extinguishes, the setting ends, then you can remotely control your TV with the remote controller.
Apr 17, 2016 | Universal Remote Control Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Proscan tv input without remote
Without its remote control, you can't select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Apr 03, 2014 | Durabrand DWT1905 TV
Telefunken 74cm tv
0386,0388,0380,0381. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 11, 2014 | Universal Remote Control Televison & Video
Changing inputs on sylvania tv
To select inputs you should have its remote control. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electro-medical.blogspot.com/
Feb 08, 2014 | Sylvania 6432FE 32" TV
Change emerson tv input without remote
As there is no menu button at the front panel of this TV, there is no way to select its input selection, without a remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 02, 2013 | Televison & Video
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Electro Med Services...
