Question about Refrigerators
No power to the evaporator fan motor - Refrigerators
  • Jack Nov 05, 2012
    model number is 596.75523400 serial # 10336612EN
  • Richard Roth
    Richard Roth Nov 05, 2012
    If you are not reading any voltage at the fan, you will need to replace the "control board". HEre is the part to order. http://click.linksynergy.com/fs-bin/clic...
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 05, 2012
5 Suggested Answers
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
tborn6
  • 700 Answers
SOURCE: evaporator fan motor issue
have yoiu tried to just unplug the unit? that would be the easiest thing to do. most units are on wheels that help you to pull them strait out from the wall.
Posted on Jan 06, 2009
bobicehouse
  • 1524 Answers
SOURCE: Evaporator fan not working!!
The fan on this model is only 12 volts. Make sure that is what your replacement is rated.
Posted on Jul 30, 2010
aaronbeth
  • 110 Answers
SOURCE: The Evaporator fan motor has no power to it the
What is the temperature in the freezer? Check to see if there is a fan switch on the schematic diagram, if so jump it out and see if it runs.
Posted on Jan 18, 2011
I HAVE A WHIRLPOOL MODEL GI6FDRXXY 07, AND THE EVAPORADOR MOTOR DOESNOT WORKING... IT NO RECEIVE THE 12 V... WHY? A NEED A WIRING DIAGRAM... TO CHECK...
If your evaporator motor is not working, you are so correct. The air circulated in the refrigerator is due to the evaporator motor fan. If left to operate without a fan to provide a heat load for your compressor, it could cause your compressor to fail. Your problem is most likely the defrost sensor inside the cover of your evaporator. It is probably stuck open and will not put power to your evaporator fan. Take you model number to Searspartsdirect.com and find the defrost sensor for your refrigerator and replace it.
Hope this helps
Dec 13, 2014 | Whirlpool GI6FDRXXY
Freezer flashing E Refrigerator flashing F what does this mean????
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Apr 04, 2011 | Kenmore Refrigerators
The top half of my fridge and freezer are not cooling. Its a side by side unit and it is cold at the bottom. ??????
The evaporator fan motor has gone bad.....or the control board has gone bad and the fan is not getting power.... check for power at the fan and if there is power change the fan motor... if not then change the board...
http://www.repairclinic.com/PartDetail/Evaporator-Fan-Motor/1174059?modelNumber=JCD2290HES
http://www.repairclinic.com/PartDetail/Control-Board/1472681?modelNumber=JCD2290HES
heatman101
Nov 24, 2010 | Jenn-Air JCD2290HES Side by Side...
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
Freezer not freezing fridge not cold, freezer frosted up
Oct 03, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
Not cooling no p0wer to evaporating fan
Part number R0161089 defrost thermostat $35 ,but if the freezer coil is defrosted there would be no power to the motor because this switch has to be chilled to about 0°F to send the power to the fan motor.
Sep 27, 2009 | Amana SXD524VW Side by Side Refrigerator
Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Apr 28, 2009 | Kenmore Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
