Question about Krups Coffee Makers & Espresso Machines
Does not start
Can t grind no power
Try a new fuse in the plug
Posted on Nov 08, 2012
99 yz 125 made a grinding niose died now wont start
seized piston, cracked internals no good whatever it is
Dec 27, 2013 | Yamaha YZ 125 Motorcycles
I am hearing a grinding noise when turning the ignition on my 2005 dodge ram 1500.Truck is automatic and runs fine when in driving.
Have an auto electrician look at the problem but I suspect that the starter solenoid is starting the armature spinning before the pinion gear is properly engaged in the flywheel teeth. If so the starter can be repaired either by a new solenoid or adjusting the pinion movement before the armature gets power.
Nov 30, 2013 | Cars & Trucks
Grinding and powers down when put into gear?
Sorry it is time for transmission service or could be to late if you have not serviced it regularly replacement may be the only option on these they were horrible transmissions anyway.Dont forget to rate my solution and leave testimonial it is how i earn my achievements Thanks in advance
Apr 22, 2012 | 2006 Audi A4
My 2001 bmw 325 cic started making an awful grinding noise today when moving the steering wheel at all to the left or right. Can also hear the noise under the hood.
It sounds like your car is low on power steering fluid. When the power steering fluid is low, the power steering pump is running dry, which makes a grinding or moaning sound. Check the power steering fluid level and top up if necessary. It should be on the left side of the engine compartment. Your owners manual should have the exact location of the power steering reservoir, and what type of power steering fluid to use.
Good luck
Matt
Jun 22, 2011 | 2001 BMW 325
Grinding noise from power steering pump or pullie
Please - for safety sake take your vehicle to a shop.
Apr 03, 2010 | 1999 GMC Safari
Grinds on start 1997 Geo tracker; will not start
see if your starter is loose then get back to me
Jan 06, 2010 | 1991 Geo Storm
Jeep grand cherokee constant grinding noise, and but in reverse with full right lock it feels like it is grabbing the o/s rear wheel and a heavy deep grind comes from it! thanks in advance
As weird as it may sound, i'd check the power steering fluid. An empty power steering fluid tank will make the power steering grind and make weird noises, and having it at full lock will worsen the noise and have no fluid to build pressure it might starting jumping the steering around a bit. If the power steering is OK then you will need to take the rear drums apart to check for any broken retainer springs preventing the pads from returning into place and it will keep braking and grinding. Could also just be some rust or a broken off metal part in the drum also, but either way you will need to take the drums off and inspect the springs, clips and pads to ensure everything is OK and nothing stays jammed into braking position. Also be sure to verify the rear brake cylinders in the drums, as it may also be them that don't return to the initial position and keep the brakes on.
Jul 08, 2009 | 1997 Jeep Grand Cherokee
Onan generator making grinding noise while cranking
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Jun 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Coffee Makers & Espresso Machines Logo
224 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
