Question about Dyson Vacuums
Shark bagless beater bar broken
Less than 6 months after purchase, my Shark upright bagless beater bar stopped working. It would partially work if I held it at a sharp angle, left or right, then just stopped turning altogether. The bar is free of hair, string, whatever.....and still doesn't turn. Can't find a repair shop in NH and don't want to have to ship it. Anyone have ideas?
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
reddevil6
  • 1673 Answers
SOURCE: I have a Hoover Savvy
The Savvy has a brush roll motor, whcih could be bad. There also is a circuit board near the brush roll motor, a circuit board underneath the tool holder, and the switch asm. in the handle. Any of which could be the cause of the brush roll not turning. Just needs to be checked to find what is causing the problem.
Posted on Jun 12, 2008
  • 172 Answers
SOURCE: beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Posted on Mar 02, 2009
ukvacfan
  • 328 Answers
SOURCE: My Oreck beater bar is not turning. The bar is
If the motor is working then check the drive belt. There's a door on the right hand side of the Oreck that comes off with a cross head screw. Check the drive belt isn't broken. If its intact then its a possibility that the beater bar has seized up - beater bars from Oreck are available although you should check EBay to see if you can get a cheaper part. Sounds like a drive belt problem though.
Posted on Mar 06, 2009
Vac Belts
  • 701 Answers
SOURCE: My beater bar is not turning so the vaccuum is not
You need to replace the belt, it has probably broken. Your actually supposed to change them yearly. Here is a link to the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
Posted on Nov 29, 2009
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Feb 22, 2015 | Shark Navigator Bagless Upright Vacuum
I need a DIY solution because my shark navigator lift away beater bar attachment stops working intermittently
If you've gotten 4 years out of a Shark you've already beat the system. Give yourself a pat on the back, throw it in the nearest dumpster, then go to your local vac shop and purchase a quality USA made vacuum cleaner that is repairable and will likely last 20-30 years. Chinese vacs are designed to last one year and parts are not made for Sharks.
Jan 07, 2015 | Shark Navigator Lift-Away Upright Vacuum
Beater bar not working
Got threads the end bearings. Try a pear of needle-nose to pull them out.
Mar 01, 2014 | Shark Navigator Bagless Upright Vacuum
Beater bar is not working
Shark Rotator Troubleshooting - YouTube
? 10:35
www.youtube.com/watch?v=H_dovG2javs
Oct 23, 2012 - Uploaded by VacBin
I show you how to fix common problems with the Shark Rotator..... I have Shark Rotator Prof Liftaway and ...
Feb 01, 2014 | Shark Rotator Professional Bagless Upright...
THE ROLLER ON MY SHARK NAVIGATOR WILL NOT STAY ON, I CLEANED ALL THE HAIR FROM THE ROLLER AND IT STILL WONT STAY ON. IS THERE A BELT I NEED TO CHECK
We have only had our Navigator for 6 months and the bar won't turn. We took the whole beater bar head apart and it was a wiring problem in the beater bar motor.
What a piece of junk this is, very poorly made and has many design flaws.
Looking for something now to take it's place!
May 09, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
My beater brush comes on for 3 seconds and quits working on my shark navigator.
Same thing with my NAV22. Called them. They walked me through some troubleshooting and then they offered to send me a replacement power floor nozzle (the entire bottom piece). They said they don't want us to open it up to replace belts, so if you registered the product when you bought and it's been less than 5 years you should be all set...
Mar 09, 2011 | Shark Navigator Bagless Upright Vacuum
Why did the beater brush stop working? how do i fix it?
check the belt it sounds like its broke take the bottom off where the brush is and there should b a belt that drives the brush
Jan 21, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Need new brush ( power beater bar) and belts
You're in luck! We carry both the belts, as well as the roller brush for your Shark Infinity model that you listed this repair under.
Here are links to both parts you are requesting:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Belt Set For Shark Infinity Bagless Uprights, Models NV30, NV31
After you receive the parts, here's a link to the manual that will walk you through, step by step on how to replace both items if you have any questions, or need help:
Shark Infinity Bagless Upright Owners Manual
Hopefully this was able to answer your questions. Please feel free to reply to this email or just give me a call if you have any further questions. If this helped, please be so kind and rate the repair, or leave some feedback for me.
Chris Jones
GoVacuum.com
May 22, 2010 | Euro-Pro NV31 Infinity Vacuum
I need a new roller bar or beater brush for infinity vacuum
Hi There,
Here's a link to that part on our website if you haven't found it already:
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Apr 14, 2010 | Euro-Pro NV31 Infinity Vacuum
Vacuums Logo
310 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
