Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
I have a ILO TV and need the codes for a RCA DTA800 converter
I have a ILO TV and need the RCA DTA800 Converter Codes to set up the remote
Already found solution with codes from Orian that worked.
Thanks
Posted on Jan 06, 2009
Code to program my JVC tv to the DTA800 Digital box
Hi debbie,
I see yiu need a code for your JVC TV to program ti the DTA800.
You can try The codes for JVC TV to program universal remote are 159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158. You can check these codes one by one.
I hope this helps.
mvincentc
May 28, 2011 | RCA (DTA800B1) Video Converter
What is the codes for a sanyo tv that will connect to a rca/dta800 converter box. I have lost my manual and need to the codes for a Sanyo television.
not for sure but try 007, i have a different brand converter box hooked to a sanyo tv and it's code is 007, i will try and find out more if i do i will post it
Nov 19, 2009 | Insignia Digital-to-Analog Converter for...
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
I have a remote control for my converter box brand rca #dta800 but i want to program my control to my tv and i dont have the code.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
look inside for the codes to your tv model and it usually is trial and error.
Jun 16, 2009 | Televison & Video
Lost code for rca DTA800B1 digital converter box
I have an RCA DTA800 converter box but I need the codes for my Magnavox...need help
Feb 19, 2009 | Jensen JER-422 Universal Remote Control
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
I am looking for code and instructions for rca tv
RCA 000,001,005,072,073,074,076,077,078,135,138,140,156,162,163,169,171,178,229,246,249,260,274,275,293,302
Dec 17, 2008 | RCA 3-Device Universal Remote
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Jun 19, 2008 | Televison & Video
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
182 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
