Ihave AWA JTM32K212A-T won't power up cost of replacement part ?
  • longgrazz Nov 04, 2012
    AWA TV 32"
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Hard to guess but unless expensive unit usually cheaper to buy a new player.
Posted on Nov 05, 2012
Why won't my 92 jeep start? Ihave a new battery and starter
maybe earth strap to chassis from engine. put a multi meter from battery neg to engine, set it to DC volts and crank the engine. should read 0 volts if ok. will read about 12 volts if earth is knackered.
Jul 12, 2012 | 1992 Jeep Wrangler
Just dies, sometimes won't start. Changed crank shaft censor, still no good
ihave a 98 grnd chrk lrdo had to replace computer on fire wall, periodicly i spray all electrical connections w/ crs electric contact spray.
Jun 01, 2012 | 2000 Jeep Grand Cherokee
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
I need a replacement remote for a nec plasma pxt 42xd2
You can purchase just about any universal remote as a replacement. If you are looking for the original equipment you are looking for part number 301-1P42HB9-01A. You can find it for sale at AWA Parts at the following link:
REMOTE CONTROL RC-101-0A PXT-42XD1
http://aware.awa.com.au/parts/NEC/PTV106+/PXT-42XD2/index.html
They currently have 96 in stock and they cost $44.00.
I hope this helps.
Aug 20, 2011 | Televison & Video
Why my passenger side power window not roll down but locks work
That is like asking why your grass grows faster one week than the next
You use the window switch a lot --- so start there
Next, is the window regulator or cable broken -when
that happens the window usually falls down
The window motor may have fail in some way
I know you should check for a blown fuse but the other
windows work & if it did blow replacing it won't do a thing
If you have & know how to use a volt meter on any setting,
start by getting access to the switches
I doubt the locks are even on the same circuit
Personally I wouldn't even approach the vehicle
without a wiring diagram
Like going on a road trip,no map,why leave home
won't find anything or get to any place
Most people ask a question & go to a repair shop
or try thing the hard way because it costs nothing
Also gives no results
Aug 04, 2011 | Chevrolet 1500 Cars & Trucks
I have Hp Photosmart 309g - it is 2 yrs old. I get alignment failure & have tried all the resolutions on the support website. First Blue didn't print then after pulling the power out everything...
Yes that is unfortunately true, if it is out of warranty they won't be able to replace the printer. However, it can be traded for upgrade for an HP factory reconditioned printer for a lesser cost.
Jun 19, 2011 | HP Photosmart Premium C309g multifunction...
In the last 2 weeks my Canon MP830 printer has been printing jiberish the first time a print job was sent to it, then when resent it printed properly. Today the printer won't turn on. What can I do ?
Unfortunately these are considered disposable printers.
If it won't power on at all even in a known good power outlet there isn't much you can do as the cost to repair it out of warranty would cost more than to simply replace it.
Other than checking the power outlet and the power cable nothing else to do.
May 31, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Hi any one got gps awa 100 car charger for sale or were i can get one thank you
car charger for my AWA gps failed. I got a phone charger with same output voltage, cut phone plug off & spliced AWA plug in.Works fine.
Jul 31, 2009 | GPS
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
