Question about Samsung Televison & Video
My samsung is connect to my router via ethernet cable but not connecting to internet
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Confirm the router is working with another computer?
Posted on Nov 05, 2012
5 Suggested Answers
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
SOURCE: I have a LG37LD490 and wish to conect it to the
i would suggest you connect via your ethernet bridge in your home network since the LG37LD490 comes with Wireless LAN for Broadband and DLNA. With the DLNA your television can join a home network of DLNA Certified™ devices, increasing the possibilities for sharing and enjoying your media right in the comfort of your living room or office.
Posted on Dec 06, 2010
  • 79 Answers
SOURCE: LG 42LK530T connect to internet
Hello pjd 28,
not too sure what the issue is but if your having problems connecting to the internet via ethernet, there is a few things you need to know. It all depends on what your tv functions. Also if your computer is DLNA compatablie, then you can stream videos on to your tv. You cannot just surf the web like you do on you computer. TV's like samsung 7000 series has this option. If your tv has applications such as youtube, then you can connect your ethernet to your modem. It should connect automatically, but if it doesn't then go to network settings on your tv through the menu on your remote and see if it says that it is connected to your network SSID. Good luck.
-Joe
Posted on Aug 29, 2011
SD Tech
  • 14553 Answers
SOURCE: how can i connect my toshiba 32AV600E to samsung HT-D455K via HDMI? but
Here is a link to the Toshiba owner manual:
http://www.regza-asia.com/pdf/LCDTV/AV600/AV600_OM.pdf
Note that the two HDMI connections on the Toshiba are for input and not for output of anything.
Posted on Jun 02, 2012
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
My router works when connected as wireless, but when I connect an ethernet cable to this, it does not work. This is required as I am trying to connect a network hard drive via the ethernet connection.
Hi. I suggest you double check first if the ethernet cable you're using is a known good cable if yes then that should be on your router configuration that enables you to use the ethernet cable, so I think you need to contact your Internet Service Provider regarding this matter because by default you should have the access using the ethernet cable, and they'll be the one to configure your router. Hope this helps
Jun 04, 2010 | Belkin (F5D7230-4) Router (587009)
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
"Service not supported" with Internet@TV.
Problem persists : ------------ ----------- ---I have configured the network in the samsung 40" LCD TV, using Ethernet cable to a router. The ping test, DNS server, GW Tests are passing ok. I am able to ping to the IP address of the samsung TV from my Laptop. My internet browsing via the service provider Airtel is otherwise working excellent with Laptop (Vista) or MacBook.
Router : 192.168.0.1 Laptop : 192.168.0.16 Samsung : 192.168.0.5 GW : 192.168.0.1
But Internet #TV gives "Service Not supported"
Any known issues?
Thanks, Ilango
Sep 17, 2009 | Samsung LN40A550 LCD TV
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
