Question about Home Security
My skytech 1010TH remote stoped working. The transmiter stpoped communicating with the receiver. It worked fine all last winter and for about a month his winter. I changed all batteries and two weeks after that it sotped working.d
4 Suggested Answers
SOURCE: skytech model no. sky-3001 changed batteries in
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: I have a Skytech 1001
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Posted on Jan 15, 2011
  • 4736 Answers
SOURCE: receiver was beeping all the
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Posted on Feb 03, 2011
Remote won't work unless next to fireplace.
There are some adjustments that can be made to improve the reception of the Skytech 3301 Fireplace Remote.
Sometimes the RF reception can be diminished if the receiver is in an enclosed metal surround such as a heat shield.
The link above will bring you to the product page where you can scroll down and download the full owner's manual. An excerpt from the manual in regards to adjusting the reception is below:
"RECEIVER ADJUSTMENT - RECOMMENDED ADJUSTMENT
NOTE: The slide button, Gray or Black, covers the ADJ access hole when installed.
A. To adjust at the receiver, use a small slotted screwdriver. Turn the adjustment screw counter-clockwise
about 5 degrees or a maximum of 1/8 turn. This should correct the distance problem.
B. If that does not correct the problem, return adjustment screw to original position and then turn adjustment
screw clockwise.
This adjustment is like tuning your radio. If you keep turning the adjustment screw, in either direction, you will go past the proper setting (tuning)."
Dec 25, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech receiver batteries keep going dead
Joe,
The heat from the fireplace can have an adverse effect on the life of the batteries. Sometimes simply re-positioning the receiver to a cooler location under the firebox and/or adding a heat-shield can improve battery performance with the Skytech remote receivers.
As a test, you could even place the receiver outside the fireplace for a period of time to gauge the effect of heat on the unit.
According to the owner's manual for the Skytech 3301 Thermostat Remote:
"For REMOTE RECEIVERS that operate on BATTERY POWER, these heat conditions can cause batteries to discharge when temperatures exceed 115 degrees F. Studies show that alkaline batteries, when exposed to a constant temperature of 120 degrees F, can lose up to 50% of their operating power. When the battery cools down, it will partially recharge itself, but constant heating and cooling will reduce the battery's normal life expectancy."
Hope this helps!
Dec 01, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a 5301. Connected last year, worked fine. Installed new batteries, connects and beeps, but fireplace won't light. All controls are in correct position.
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first.
Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve.
If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
Nov 29, 2012 | Procom SSU320RHN-GB Heater
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
Receiver was beeping... Jiggled it ... Stopped beeping... Now not working ...tried to reset transmitter with receiver but will not work .... Did replace batteries and recharged receiver as well ... Remote...
There's no quick answer to your problem, as it may be your gas fireplace that's causing the problem. If you still have your Owners Installation Manual look at page # 7 (Trouble Shooting), this should help you solve your problem. If you don't have your Owners Manual, you can download it online from SkyTech's website. If all else fails contact SkyTech's Technical Service Dept @ 888-672-8929
They are friendly and knowledgeable folks to work with.
Jan 11, 2011 | Skytech 3301-BE Gray Five Button...
I have a Skytech 1001 TH-A thermo remote. Everything was hooked up correctly, but the remote continues not to work. When I turn the remote off, the fireplace comes on and vice versa.
Jan 02, 2011 | Skytech 1001-A Fireplace Remote Control...
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
Home Security Logo
920 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
