Question about Maytag Neptune MAH5500B Front Load Washer
MAH5500B washer won' spin. LR appears on display.
PROBLEM POSTED: MAH5500B won't spin. LR displays.
SOLUTION RECEIVED: That means locked rotor. You need a new motor usually comes in a kit .12002039 is the part number. Try unplugging the jp4 connecter and see what happens.
QUESTION: Where is the jp4 connector located?
  • nildaebaez Jan 05, 2009
    Yes, I have the same problem with this washer Neptune MAH5500B frontload.It does not spin or wash at the end of the cycle an Lr code appears.It is easy to solve? can I do the job ? what is the cost on the motor kit? Thanks a lot for your help! Elsie
  • Myrna Jan 06, 2009
    tzweeb, Thank (((you)))! Right on the money! I did call Maytag as you suggested and was told that since the machine IS over 5 years old, they will not 'help.' My serviceman (who verified your diagnosis) called the local parts dealer; the part was in stock; the price is $l90. Again, thank you SO much for your help. Allow me to wish you a sparkling day!
    Auntieem
  • 318 Answers
Maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Posted on Jan 06, 2009
My washer stops working when there is between 8 to 11 min left in the cycle then gives me a Lr on the digital readout. It never finishes the last spin. I am not sure if this is the model, I do not have...
Hello, Thank You for using FixYa. I will be helping you today.LR means locked rotor. Usually when this happens it needs a new motor or motor conversion kit depending on the model.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6500
yes there is a control board at the back of the machine if it got wet it will be damaged and eventually the machine not might work at all its easier to call a repair man instead of all the trouble doing it your self and it is int costly at all
Sep 09, 2008 | Maytag MAH6500 Neptune Front Loading...
What does Lr on the display mean? There was a considerable amount of water on the floor and in the machine. I could not get the door to unlock to see what was going on, it just beeped several times and...
the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Service and repair manual above.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
At the spin cycle it shuts dwn and has Lr on the screen when I shut it off to just use spin cycle it does a count down but not the spin then Lr comes up again
Hi
Thanks for using FixYa. Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Washing machine
Usually, the LR or 'Locked Rotor' indicates a problem with the motor / motor control board or MBC. The MBC is located near the floor on the right side. See www.neptunehelp.com for disassembly photos. The original MCB's had a high failure rate so Maytag redesigned the MCB and the motor. The motor conversion kit is part number 12002039, which includes the new motor, MCB, harness and takes about an hour to install. You can inspect the MCB for either a blown 10 amp fuse or if you see components that are burnt or discolored. If either of these is the case then you will need the motor conversion kit.
In addition, as your Neptune ages you might notice the spin cycle getting louder to where it will sound like a jet plane taking off. If this is the case then you can replace your bearings and seal kit. See www.neptunebearing.com. You can also rent a special Neptune bearing tool called the tony tool which includes the use of a DVD that shows you how to take apart Neptune, replace bearings and install the 12002022 seal kit. I hope this helps...
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
that means locked rotor you need a new motor usually comes in a kit 12002039 is the part numberr try unplugging the jp4 connecter and see what happens
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Need repair kit for LR Code on Neptune Front Load Washer. Found it once a few months ago, but lost the printout and unable to locate the site again.
The part number for MAH5500 and MAH3000 is 12002039 you are going to want to bring your model and serial with you to where ever you buy it to confirm, but that part number is the most recent one, it contains the motor, motor control kit etc..which LR meaning locked rotor that would be the fix
May 01, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
309 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
