Does the gemini xl 500 2 have a built in pre amp
SOURCE: gemini xl 500
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Posted on Aug 16, 2008
Grubhead
  • 5484 Answers
SOURCE: I have tried too hook up my Gemini XL-500, to a
No! The amp must have a magnetic cartridge pre-amp to increase the sound level. If it has one it will say "phono" on the inputs on the back and have a "turntable" - or "Phono" selector switch. If it doesn't have one (many new surround amps don't) you won't be able to play it properly untill you get a "magnetic cartridge pre-amp". This will make the signal loud enough to be used on a normal aux imput of the Sony.
Posted on Jul 19, 2010
adracamas
  • 344 Answers
SOURCE: I need a replacement cartridge for the gemini xl
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
Posted on Aug 03, 2010
Grubhead
  • 5484 Answers
SOURCE: i have brought a set
Here
http://www.stylusplus.co.uk/gemini-xl-500-mk-ii-record-player-stylus-8489-p.asp
Posted on Feb 15, 2011
  • 126 Answers
SOURCE: Where can I download a
Hi, you may download the manual through this link:
http://media.musicalplanet.com/pdf/GMN041.PDF
This link will lead you directly to XL-500 Manual.
Thanks for using FixYa. eibraz
Posted on Sep 02, 2011
What do I need regarding preamp/cartridge matching?
Cartridges require no special pre-amp. If your amp has one built in the sound from the deck will come out at the same level as other functions. If the amp has no inbuilt pre-amp you will still hear sound (if the cartridge is working) only the volume will be too low to listen to. All you need do is connect the record player to the amp and see if you can hear the sound. If you can't then you need a magnetic cartridge pre-amp. By the way if you need a new cartridge you don't have to stick with a Gemini make. You can use any one you want as long as it will fit into the headshell. There some better makes of cartridge out there, that will give better sound quality. It all depends on what you want to spend on a cartridge!
Jan 04, 2016 | Gemini XL-100 Turntable
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Aug 03, 2010 | Gemini XL-500 Turntable
I have tried too hook up my Gemini XL-500, to a Sony Digital Audio DTS discrete 6ch Amp , but get very low volume, tuner & cd dvd, volume is fine, does this have anything to do with the ground?...
Jul 16, 2010 | Gemini XL-500 Turntable
How do you hook up gemini xl 300 turntables to a gemini pmx 500 mixer
red n white phono leads from deck 1 to channel1phono ports on mixer
red n white phono leads from deck2 to channel2 phono ports on mixer
then output out to amp
Jul 06, 2009 | Philips gemini XL-300 Turntable
Gemini xl 500
Aug 10, 2008 | Gemini XL-500 Turntable
Turntable problem
You will need a phono preamp. Ipods, radios and cd players all give out a LINE level signal..which means you can plug headphones or speakers, adjust volume and be set. A turntable needs a phono preamp. Usually a dj mixer or stereo receiver with a phono input is all that is needed. A simple phono pre amp is like $20 from radio shack.
keep me posted.
Oct 25, 2007 | Gemini XL-500 Turntable
301 people viewed this question
 Grubhead
Grubhead
