Question about Hitachi Computers & Internet
Hitachi 160 IDE Hard Drive
Hi, My pc worked until yesterday, got the ZLOB virus. So I tried to re-install windows xp professional using disk, when formatted hard drive using the wizard on the cd it got to 100% formatted then said hard drive corrupted, how can i format the hard drive to enable xp to go back on.
    President:
  • 948 Answers
You can download utilities from Hitachi here - http://www.hitachigst.com/hdd/support/download.htm You didn't say which drive you have, but one of the utilities there will allow you to run diagnostics on your drive, format, and partition it.
Posted on Jan 04, 2009
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
Bios reconizes new hd drive but xp pro does not
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
I am trying to format my hard drive on my stalite l305=s5875. i shows the hard drive in bios but when the windows disk looks for it theres nothing there. no hard drive appeares
If your laptop has a SATA hard drive then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | Toshiba Satellite L305-S5875 Notebook
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
Mar 25, 2012 | Computers & Internet
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Toshiba PSAG8U-023019 xp install problems
The reason is that Windows XP doesn't come with SATA hard drive drivers. You have two options. The easiest being go in BIOS and check for IDE compatibilty mode or IDE emulation. Enable this and XP will install just fine. Your other option is to use a program called nLite and download SATA drivers from intel's website and you can incorporate them into a Windows XP slipstream install disc and it will install no problem.
Nov 21, 2011 | Toshiba Satellite A305-S6883 Notebook
Hi i purchased a dell 1318 laptop from china suddenly i cont install xp it,s support only win7 while trying to install xp it will display the error message like this
Your laptop may have a SATA hard drive.
Nov 13, 2011 | Dell Inspiron 1318 Laptop Computer PC...
I have acer 4741z, its having problem and already formatted hard drive, i tried to install win xp using installation cd, its running ok until the blue screen appear and struck there. How to install win xp,...
It is not a hardware issue. It is easy to install Windows 7 in your laptop but if you want to install Windows XP you have change the Hard Disk type to IDE. For that you have to change settings in your BIOS. After changing to IDE you can continue your installation normally as you done earlier...
thanks & regards
Anas K A
Jun 27, 2011 | Computers & Internet
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Computers & Internet Logo
120 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
