Question about Philips 32PW9523CG 32" TV
Philips 32PW9536 Screen distorted to the right hand side
My TV has started to distort the the right hand side of the screen, it starts shortly after i turn the tv on and just suddenly jumps and the right hand side is bowed in at the top and bottom and the colours also blur and go out of alignment. not sure if this will work, but i will try to post a picture tv1.jpg
  • 1 more comment
  • jon hayre May 20, 2007
    picture of sky menu
    the image is stable by the way and once it has settled it remain exactly the same. I have checked all the internal connections where possible and banging the set makes no differance (lol)
    tia
    Jon.
  • jon hayre Jun 29, 2007
    if anyone has an answer to this, i'd be interested still. I'd like to fix this tv and donate it to my grandma (or the home she is staying in)
    tia.
    Jon.
  • Philips Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the bPhilips 32PW9536 Screen distorted to the right han - 69189a5.pngt fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Screen looks distorted on the right side. almost like 3d colors blue and yellow
Make sure there are no speakers sitting next to the TV. The magnets from speakers can create such distortions.
Mar 02, 2009 | Philips Televison & Video
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Jun 28, 2008 | Philips 30PW633R 32" TV
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
