Question about Breville "Ikon" Tea Kettle Electric Kettle
Kettle does not turn off automatically
The button you press to turn on the kettle does not turn off. I have to push the button to turn off the kettle. I did not have to do this before.
Cuisinart PerFecTemp Cordless Kettle
You can't, there is no adjustment provided for.
Jul 16, 2016 | Cuisinart CPK17 Electric Kettle
The lid is stuck
Have you tried pushing your lid down to make sure catch doesn't hang-up before pushing back on the button and pulling it upward?
If that doesn't work it maybe damaged (melted by steam, overuse or gunked up with heavy mineral deposits) but to be honest we don't ever open ours. We fill from the pour spout just fine with the lid always closed. You can pour in your descaler the same way.
Hope this helps a little...
Dec 07, 2013 | Oster 5965 Electric Kettle
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
Jul 12, 2013 | Applica Black And Decker Cordless Electric...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Jan 11, 2011 | Oster 5965 Electric Kettle
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
Aroma 3.0L electric heater/kettle stop dispensing
I waited about an hour and it the problem stopped.
Dec 13, 2008 | Aroma Kitchen Appliances - Others
Overheating kettle
this same thing happened to me
Sep 10, 2008 | Bravetti EK119H Electric Kettle
Siemens porsche kettle om switch problem
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Feb 04, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
93 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
