Question about Schwinn 250 Recumbent Exercise Bike
Shwinn 250 has no resistance when I pedal.
Has never had any resistance when I pedal.
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
I am trying to find any and all information on a Vintage Shwinn mens bicycle model or serial number that I found on the left back wheel frame is M96673. I have been searching the internet & all old Shwinn...
I think the bike was built in Dec of 1959 from the # but the # is only a date code it does not give any hint on model a picture would be the only way to make a better guess, model name was painted on chain gard
Sep 28, 2013 | Cycling
Golds gym 380 elliptical is not increasing resistance
follow this steps, God bless you
    • Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    • Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
Nov 14, 2012 | Golds Gym StrideTrainer 380 Elliptical
Shwinn 220 won't prdal
you can call Treadmill Doctor and they will help at 800-750-4766 I am also attaching the manual.
http://download.nautilus.com/supportdocs/OM/Schwinn/SCH.120.220.OM.EN.FR.pdf
Jul 04, 2012 | Schwinn 220 Recumbent Bike
Gear shifter will not go into gear and cannot release from park. Car was parked on level ground. After returing to the car and turning the ignition on, the gear shifter would not go into any gear. Car was...
Shift Interlock System
The shift interlock system prevents shifting from PARK unless the brake pedal is depressed. The shift interlock system consists of a shift lock actuator mounted at the base of the steering column or on the floor shifter mechanism. If the ignition switch is in the RUN position, the shift lock actuator is ON unless the brake pedal is depressed.
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The shift interlock system does not release/lock correctly
  • Circuitry.
  • Fuse(s):
    • F1.5 (7.5A).
    • F1.27 (5A).
  • Shift lock actuator.
  • Brake pedal position switch.
  • Go To Pinpoint Test D .
PINPOINT TEST D: THE SHIFT INTERLOCK SYSTEM DOES NOT RELEASE/LOCK CORRECTLY Test Step Result / Action to Take D1 TEST THE BRAKE LIGHTS
  • Apply brake pedal and view brake lights.
  • Do the brake lights illuminate?
Yes
GO to D7 .
No
GO to D2 . D2 TEST FUSE F1.5 (7.5A)
  • Check fuse: Fuse F1.5 (7.5A).
  • Measure the resistance of fuse F1.5 (7.5A).
  • Is the resistance less than 5 ohms?
Yes
GO to D4 .
No
GO to D3 . D3 TEST CIRCUIT 729 (RD/WH) FOR A SHORT TO GROUND
  • Disconnect: Brake Pedal Position Switch C278.
  • Measure the resistance of circuit 729 (RD/WH) at brake pedal position switch C278-5.
  • Is the resistance greater than 10,000 ohms?
Yes
GO to D4 .
No
SERVICE circuit 729 (RD/WH) for short to ground. TEST the system for normal operation. D4 TEST CIRCUIT 729 (RD/WH) FOR AN OPEN
  • Measure the resistance between the output side of fuse F1.5 (7.5A) and brake pedal position switch C278-5, circuit 729 (RD/WH).
  • Is resistance less than 5 ohms?
Yes
GO to D5 .
No
SERVICE circuit 729 (RD/WH) for open. RETEST the system. D5 TEST THE BRAKE PEDAL POSITION SWITCH
  • Measure the resistance of brake pedal position switch (C278) while open (OFF) and closed (ON).
  • Is the resistance of the switch greater than 10,000 ohms while OFF and less than 5 ohms while ON?
Yes
GO to D6 .
No
INSTALL a new brake pedal position switch. TEST the system for normal operation. D6 CHECK CIRCUIT 810 (RD/LG) FOR A SHORT TO GROUND
  • Disconnect: Shift Lock Actuator C2008.
  • Measure the resistance of circuit 810 (RD/LG), shift lock actuator C2096-1.
Yes
GO to D7 .
No
SERVICE circuit 810 (RD/LG) for short to ground. TEST the system for normal operation. D7 CHECK CIRCUIT 810 (RD/LG) FOR AN OPEN
  • Measure the resistance of circuit 810 (RD/LG) between shift lock actuator C2096-1 and brake pedal position switch C278-6.
Yes
GO to D8 .
No
SERVICE circuit 810 (RD/LG) for open. TEST the system for normal operation. D8 TEST FOR VOLTAGE ON CIRCUIT 1003 (GY/YE)
  • Measure the voltage at shift lock actuator C2096-2, circuit 1003 (GY/YE).
  • Is voltage greater than 10 volts?
Yes
GO to D12 .
No
GO to D9 . D9 TEST FUSE F1.27 (5A)
  • Check fuse: Fuse F1.27 (5A).
Yes
GO to D11 .
No
GO to D10 . D10 TEST CIRCUIT 1003 (GY/YE) FOR A SHORT TO GROUND
  • Measure the resistance at shift lock actuator C2096-2, circuit 1003 (GY/YE).
Yes
GO to D11 .
No
SERVICE circuit 1003 (GY/YE) for short to ground. TEST the system for normal operation. D11 TEST CIRCUIT 1003 (GY/YE) FOR AN OPEN
  • Measure the resistance of circuit 1003 (GY/YE) between output side of fuse F1.27 (5A) and shift lock actuator C2096-2.
Yes
GO to D12 .
No
SERVICE circuit 1003 (GY/YE) for open. TEST the system for normal operation. D12 TEST CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance of shift lock actuator C2096-6, circuit 57 (BK).
Yes
INSTALL a new shift lock actuator. TEST the system for normal operation.
No
SERVICE circuit 57 (BK) for open. TEST the system for normal operation.
Jun 08, 2017 | 2006 Lincoln Navigator
Left pedal has no resistance right pedal is fine
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Nov 11, 2010 | Stairmaster 4600PT Stepper
I have a 1990 Lexus 250 ES. Brake lights inop.
check the brake pedal switch by connecting a test light to it and ground.
When the pedal depresses you might hear a click or see the button depress.
The test light should light or not light changing as you press and release the pedal.
Another way to do this is to change the brake pedal switch and see if it works.
I hope this helps.
Jul 05, 2010 | 1990 Lexus ES 250
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Jan 04, 2010 | Exercise & Fitness
Removing the crank arm off a shwinn sierra
You will need a crank puller which is a specialized tool that does not justify purchase unless you plan on using it a lot. That means a trip to the bike shop which is a good idea anyways as they will have to match up the crank arm for you as they come in sets.You will also need a new set of pedals and there are lots to choose from.
Mar 08, 2009 | Schwinn Sierra DSX Adult Comfort Bike
Schwinn 250 Recumbent Exercise Bike Logo
65 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
