Question about Pentair OptiFlo Aboveground Pool Pump 15 HP Vertical Discharge ()
My optiflo pump is making a high pitch noise when I run the filter. How do I stop it?
    Top Expert:
  • Pentair Master
  • 5,775 Answers
Bad motor bearings replace motor or pump
Posted on May 08, 2016
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: our dynamo CA04-26 pool pump is making a whining
The bearings are likely failing and they are not open to allow for re-lubrication. You can replace them yourself or take the motor to a local electric motor repair shop to have it done for you. A shop will probably cost about $40 to $50 for parts and labor. You should also replace the seal at the same time. The cost for the seal is under $10 and the labor shouldn't change.
Posted on May 29, 2010
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Washer makes high pitched noise after draining
This is due to the fact that the draim pump is still running DRY and so makes the high pitch noise. Check the timer or reset to a low spin dry cycle. If not check the drain circuit power using a multimeter from the program controller unit.IF there is power and the motor makes noise then remove and check if the pump is clogged, clean and reset.
check this link:
Drain pump
Jul 02, 2012 | Amana Washing Machines
My GE 500 dishwasher is making a high pitch noise. There is also no water in the bottom of the dishwasher. I think it might be the water pump.
pump running dry(without water)
1)check the water hose connected to the machine(solenoid filter block)
Jan 07, 2010 | GE Dishwashers
High pitched noise
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Sep 08, 2009 | GE Refrigerators
We have a hayward pump and the motor keeps stopping and tripping the circuit breaker. What could it be?
The motor might be too powerful for the line it's on, (usually a pump should be on a somewhat dedicated line) no Ac's running on same breaker.
An extension cord longer then 6ft is also a suspect in not allowing the pump the draw enough power.
The pump may not be drawing enough water, overheating and tripping the breaker, or the motor might have rust on the inside causing the armature not to spin freely, and shut off. (usually motor will make a high pitch noise) while running)
Jun 29, 2009 | Hayward Pro Series 18" Above Ground Pool...
FUEL STARVATION
need to change a new pump.
Nov 12, 2008 | 2002 Land Rover Discovery Series II
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Pentair OptiFlo Aboveground Pool Pump 15 HP Vertical Discharge () Logo
69 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
