Question about Dell All-In-One Computer / AMD Athlon II X4 Processor / 23" Display - Mercury Silver (IO23055611MSL) PC Desktop
I have an achi port0 device error and it says press f1 but it will no longer allow me to press f1 What do I do?
    Sergeant:
  • Dell Expert
  • 504 Answers
Need to re install window if you can
Posted on Dec 01, 2013
Startup screen
select the first boot option and press enter
Dec 02, 2013 | Gateway Computers & Internet
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Ahci port0 device error
This indicates the hard drive is bad and close to failure, backup all critical files, test the hardware for errors using windows tools, it can repair files and attempt repairs on bad sectors.
May 28, 2012 | ASUS Computers & Internet
Is it posible to set t5he bios to ACHI mode ?
yes ..if it supports it ..usually for a new hdd drive it will not support it cause it will need a achi driver ..and this should be added as a 3rd party by pressing F6 when it asks for xp ..and by browsing for it in the other operation systems..
I guess if you install it as Sata as ide ...(selected in bios ) and after that install the raid and achi driver and go back to bios and change it back ..it will get it ..In the worse case ..you do not have the correct driver and it will say there is no hdd plugged or give you memory error with a blue screen
Jan 18, 2011 | Acer TravelMate 243LC Notebook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
1801-microcode patch error
Hi according to HP memo see the following answer hope it help:
DESCRIPTION After installing a different system board or processor in systems described in the "Scope," the systems may halt during POST and display an 1801 Microcode Patch Error with a prompt to press the F1 key to continue.
NOTE Pressing the F1 key will allow the system to continue. However, processor performance may not be optimized and the error will repeat each time the system is restarted. HP recommends that the microcode be updated to ensure optimum compatibility and performance.
Sep 09, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
When booting up the screen scrolls to ''Auto-detecting AHCI PORT 0..'' then stays there for 5 minutes then displays ''Reboot and select proper boot device or insert boot media in selectec boot device and...
In your BIOS use IDE(IDE mode). This lets the Sata drive run without any special drivers. You loose hot swap and native command queuing.
ACHI(Advanced Controller Host Interface) is for things like hot swap and native command queuing(more useful for servers).
If you plan to hot swap drives later then ACHI is a good option, but requires a driver on windows install. You may be able to change it after windows is installed.
Mar 31, 2009 | Computers & Internet
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Dell All-In-One Computer / AMD Athlon II X4 Processor / 23" Display - Mercury Silver (IO23055611MSL) PC Desktop Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
