Question about Singer Sewing Machines
Underthread in sewing machine keeps breaking - Singer Sewing Machines
  • Singer Master
  • 7,365 Answers
I am assuming your talking about the bobbin thread, so that is
the information I am sending you
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Posted on Nov 06, 2012
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
SOURCE: my thread keeps om breaking i have juki lu1508n please help
try extending the looper just a hair. loosen the screw and pull past the stop just a fraction.
Posted on Jun 07, 2008
  • 76 Answers
SOURCE: The thread breaks after sewing about 4 inches.
http://www.sewusa.com/Sewing_Machine_Manuals/Dressmaker_Manuals/Dressmaker_101_Instruction_Manual.htm
You do not say what model you have. Check this site out, if you need a manual.
What you need to do is to give it a good cleaning.
MAKE SURE YOU KEEP THE SCREWS WITH THE PARTS TAKEN OFF AND MAKE NOTE OF HOW YOU TAKE THING APART SO YOU CAN GET IT BACK TOGETHER
If this is the old metal machine, (I love them) remove the screws and plate on the top, (set this aside)
remove screw and part from the left side of machine, (set aside)
remove the needle (note how needle comes out, flat side in the back)
remove the needle plate
You are now able to see most of the inner workings of the machine
Using a can of air (do not put too close to machine parts) dust all the open parts. Can also use old fime paint brushes to get into dmall areas
now using ONLY sewing machine oil, TURN the hand wheel by hand, put a drop of oil on parts that go in and out of each other, rub over each other (on top, over the needle area and in the bobbin area, (IN bobbin area you can use a q-tip with oil to rub the area)
If turning the hand wheel by hand to oil moved freely, you can plug in machine and run machine to get the oil in all the parts (this will lubricate the parts you just oiled.
Put machine back together,
Use the air agsin to dust between the tension disks.
When winding the bobbin, make sure it winds even up and down.
thread machine and try
MAKE SURE YOUR BOBBIN THREAD AND TOP THREAD ARE PULLED TO THE BACK BEFORE SEWING AND HOLD THE THREADS FOR THE FIRST FEW SITCHES, IF NOT THE MACHINE WILL PULL THE THREADS AND YOU WILL GET BREAKAGE
GOOD LUCK
Posted on Sep 05, 2009
Testimonial: "Thank you for your advise. I know the machine needed oiled. The thread still breaks, but now it will sew a little longer before the thread breaks."
  • 96 Answers
SOURCE: My sewing machine keeps jamming and the needles
maybe it sounds like the feed dog is out of alignment, and the needle hits when it travels up and down breaking the needle
Posted on Dec 13, 2009
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
Loose underthread and no zig zag
Lower thread tension can be adjusted by tightening (clockwise) the small screw in the bobbin case. The specifications call for 12-20 g resistance when pulling the thread slowly. I suggest tightening in increments of 1/8 turn and trying the machine each time. Also, mark the position of the screw in its original position should you need to return to the original setting and start over (use a piece of tape and place a mark where the slot in the screw is). I don't understand what you're saying about the zig zag problem.
Mar 12, 2014 | Husqvarna Sewing Machines
How do i fix my sewing machine underthread keeps breaking
Nov 04, 2012 | Sewing Machines
When i thread the sewing machine and sew, the stitches do not stay
Possible
you need to change the needle, if it is a little broken at the head, it's not grabbing the underthread.
goog Luck
Jun 23, 2011 | Sew Smart Compact Cordless 17390B Sewing...
Motor is spinning- needle not going up and down.
Check that the inner part of the flywheel is tightened up. This has to be loosened when winding a bobbin for underthread. Easy to forget to re-tighten it for sewing.
Apr 14, 2010 | Kenmore Sewing Machines
The needle won't pick up the underthread... meaning it doen't mak
You may need to retime the machine, if you email me I can attach instructions. drivewithken@blueyonder.co.uk
Nov 05, 2009 | Singer Sewing Machines
Small loops in the underthread
If the hook of the machine has a small burr on the point it can and will snag the upper thread and keep it from locking securely. The hook is what the bobbin case snaps on to. Take some light metal sanding material and polish the point to remove burr.
Jul 19, 2009 | White Sewing 1888 Mechanical Sewing...
Sewing Machines Logo
57 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
