Question about Honeywell HV-180 Floor / Box Fan
I was wondering how to clean a 14F0 fan? - Honeywell HV-180 Floor / Box Fan
  • 25 Answers
All you have to do get your vacum cleaner or unscrew all screws before opening your fan.
Posted on Apr 16, 2009
Model# 14f0 not working
Check your capacitor to see if it's OK. Hampton Bay is just a low-end store brand made from less expensive parts. Remember you get what you pay for. When buying a fan try to get a fan with at least a 13 degree blade pitch.
May 31, 2013 | Hampton Bay Dryers
Sf 1118
minolta photocopier di 520 code 14f0
May 13, 2013 | Sharp Office Equipment & Supplies
Have several small DT-70 table fans. Wondering is it possible to take them apart for cleaning? I have NO idea where my manuals are, bought them several years ago. If they cannot come apart for cleaning,...
There are 6 screws, deeply recessed, in the rear of the fan case. (At least that is how they are on mine, phillips or cross head)
Once they are loosened, the front and back will come apart. I Do that annually so it can be thoroughly cleaned..
Otherwise, I use a toothbrush to fit between the slots to get most of the dust, also a paintbursh with stiff bristles for the outside grills.. Similar small brushes should work for loose dust. Also can blow out loose dust with a shop vac with blower capability.
Jul 21, 2010 | Dryers
I have replaced the motherboard and power supply, but neither of the fans work, the cpu fan or the system fan. I get green light, which I am sure is the backup power, but I am stumped. I am wondering if...
Sounds like the memory to me. If you have more than 1 stick of memory try testing 1 at a time. Sometimes memory might just need a clean, use an ink rubber to gently clean the contacts then any debri with a soft clean brush. A can of compressed air comes in handy for cleaning out the memory slots.......hope this works
Feb 20, 2010 | Intel D865GVHZ Motherboard
Very soft ticking noise from the power supply fan
There may be some build up on the fan blades that the compressed air could not free. try using a Q-tip to clean anything stuck on the blades.
Aug 24, 2009 | Computers & Internet
My 55vs69a temp and lamp indicator lights are flashing, we replaced the bulb last year, we were told that the cooling fan for the bulb is not working account it is too warm where we have the tv and the...
The Lamp Fan should be open enough to clean. I wonder if the fan is turning at all causing the error to occur. It is always good to keep all the vents clean so air can circulate.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 55VS69 55" Projection HDTV
My CPU fan doesn't work. When I turn the computer on, it gives me the HP blue screen then a black screen saying that the CPU fan is broken. When I look at it, it has a lot of dust. I am wondering if I...
The cpu fan is located on top of the heatsink
the heat sink is a large silver square with slits on the top.
It's really easy to indentify
Just clean it out using some computer air spray, found at bestbuy and walmart.
Also, when your looking at it, make sure the cable is connected to the motherboard
I hope this helps!
Jul 15, 2009 | HP Computers & Internet
Cleaning a HOneywell 14F0 fan
Norm I have this fan & have removed those screws.   Look directly above the switch on the back of the fan, let your eye travel up to the extreme outside edge. Such as where you'd find 12 o'clock on a timepiece.   The screws are very small.  About the size of the head of a finishing nail.
Follow the edge around to 2 o'clock, 4 o'clock, and so on.  Don't blink.
I used a very small philips head screwdriver, the same size as for doing watch or eyeglass repair.  Remember to have a secure place to put the screws, such as a pill bottle, or lid.
And the screws can be difficult to remove, apply a lot of force downward on the screwdriver and turn s-l-o-w-l-y.  Don't strip the head of the screw.
Good luck, Liz/Bizzie Lizzie Atlanta
Jun 06, 2009 | Honeywell HV-180 Floor / Box Fan
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Cooling fan
I have a noisy video card fan,I unpluged it from the card and installed a case cooling fan,so far so good.no noise!!
HO
Apr 26, 2008 | ATI All-in-Wonder X800 XL, (256 MB) PCI...
Honeywell HV-180 Floor / Box Fan Logo
257 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Iron
Iron
richie46
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
