Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Blue dots all over screen and getting worse
Pretty much it just started with a few dots, and progressively gets worse as time goes on.
TV works fine, other than the blue dots. Tiny dots, like the stars in the sky.
  • 4 more comments
  • tbtl Jan 04, 2009
    Mine also has "fingers' of blue on the top of the screen and on the right side. It's only 3 years old!!!
  • ChevotaSS Jan 09, 2009
    same as above, started with a few and has gotten worse. looks like watching star wars in the back ground only blue instead of white
  • Anonymous Jan 19, 2009
    same problem than the lamp blew out
  • jthigpen Jan 31, 2009
    Our TV is four years old, and has blue light down the left side of the screen, and blue dots scattered throughout the screen, as though pixels have burnt out. We just replaced the lamp, and it didn't help at all.
  • jgconniff Feb 22, 2009
    Same problem as described by the others. More and more blue dots show up everyday. Our set is 4 yrs. old too.
  • Anonymous Mar 21, 2014
    Sky goes into standby and switches off tv at same time every morning
    Genius:
  • 2,920 Answers
Dead pixels you need to have it looked at
Posted on Jan 04, 2009
Can a blue dot on a tv screen get worse or stay the same.
One little blue dot is not enough to warranty the television. If you read all the documents on the set, it will tell you that some imperfections in the display are allowed. The good news is that it wont get any worse
Feb 23, 2015 | Element Electronics Element 50" Class...
I have about five white spots on my screeen tv. what is that from?
That is the first sign of the DLP chip failing ,the number of white dots will increase as time goes on.
The only solution is to have the DLP chip replaced, but it is an expensive part. You can call Samsung at 1-800-samsung to find the nearest service center.
Jun 14, 2011 | Samsung HCM4215W 42" Rear Projection...
Near the bottom edge of the screen on my Wega KF-50WE 610 has appeared a ''blue haze'' that appears after the TV has warmed up. It started a few days ago as ''fuzzy blue dots'' about the size of silver...
This was caused by a defect in the optical block of the TV. It will only get worse with time and the only way to fix it is to replace the whole optical block which is very expensive (over $1000 usually) and time consuming (you need to take the whole TV apart). However, since it was a defect, there was a class action lawsuit that caused Sony to extended the warranties for certain models on the optical block for parts and labor. Call Sony to see if your model was one of the ones they extended the warranty for.
Oct 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
When I first turn on my TV, I get horizonal faded lines
it probably has leaky capacitors in the hyper board or the video process board, this repair requires a qualified tv repairman, you can't do it yourself, alot of actual repairman can't handle this repair. it will get progressively worse as time goes on the more leaky the capacitors become.
Sep 07, 2009 | Toshiba 42H81 42" Rear Projection...
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Florescent blue dots on the screen
pixels are going out on the screen
Feb 19, 2009 | Televison & Video
HDTV is getting blue dots and the right side has turned blue
These issues are problems in the light engine (optics block)
the dots are called "starfield" and the geometric is "roadmap"
replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
part # A-1606-008-A
Nov 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
36" CRT Toshiba has that vertical issue mentioned on here a bit
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Sep 17, 2006 | Toshiba 36A41 36" TV
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
637 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
