Question about Whirlpool Duet GHW9150P Front Load Washer
After washing clothes, water stays in the detergent tray.
After running a wash cycle, there is a lot of water (tray is almost full) that stays in the detergent tray. Just recently started, we clean our trays often.
  • 247 Answers
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Posted on Jan 04, 2009
Why do my front load ge washer leave lint on the clothes?
A lot of build up from front loaders is caused from "scrud" excess detergent or constant cold water use. Place a cup full of Epson Salts in the machine and run through a hot wash cycle every 4 weeks or so and this will help keep bowl clean.
Dec 03, 2014 | GE Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water and detergent are in the bin after wash cycle
check to make sure water lines are not clogged and detergent tray is not caked up
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Detergent tray full of water
Hi....Lift the softener cover off the tray and you will find the syphon tube or the cover underneath are blocked. Push some wire through the syphon tube to make sure it is clear and give everything a good wash.
Jun 03, 2009 | Zanussi WJD1257W Front Load Washer
Water in detergent dispenser
I think this is normal. Mine does too.
Jun 21, 2008 | LG WM2688H Front Load Washer
Detergent tray has too much water @ end of cycle...
Try pulling out the tray gently. Your tray is clogged with detergent which you have to remove with a tooth brush or something.....minor problem u have.
Sep 27, 2007 | LG WM2277 XL Front Load Stackable Washing...
Whirlpool Duet GHW9150P Front Load Washer Logo
309 people viewed this question
Dan Webster
Dan Webster
Sal De
