Question about Dell W3202MH 32 in. LCD Television
I got a dell W3202MH LCD TV from a hotel, the tv was working but when i took it home, as soon as I turn it on only see the dell logo and after that nothing just a blank screen, also can select other input either with the remote or the buttons on the tv, any idea
  • Anonymous Mar 15, 2014
    The tv came from a hotel and has many functions locked out. How do I unlock it?
  • 127 Answers
The TV was programed to the Hotel Is in a lock mode you may need a code.Go and get IT.
Posted on Nov 05, 2012
  • jose_2002_20
    jose_2002_20 Nov 27, 2012
    What if the hotel doesn't know the code
JigSaw007
  • 157 Answers
SOURCE: OSD menu locked
When the OSD is locked, pressing the menu button again and it will take user to OSD LOCK menu. Press (+) to unlock and allow user access to all applicable settings.
Posted on Aug 12, 2008
SOURCE: Only powers up to Dell logo
I Have a Dell Model # W3201C With same problem since i am a tech.
and am experienced on LCD's after taking set apart 1 found Problem's
on Hi-Voltage board that power's the front panel . seem's that the 24 volt
line from the main power supply is bad maybe even one of the surface
ic's is draging the line down.... don't know if the hi-voltage board is
available or not this board would probably fix this problem... also would
like to know it's part # if it is out there somwhere ////
Posted on Aug 13, 2008
  • 90 Answers
SOURCE: DELL LCD TV locked up w/screen message "main menu locked"
without a remote and disabled keypad keys, the only other option, is to open the unit up a physically RESET the TV. remove the cables from the power board. i believe it has a phillips head screw. careful when you separate the rear cover from the front cover. there is a board screwed in the lower right corner, there is a connecter and a ground cable screwed to the rear cover. take your time prying on the rear cover. once you separated the two pieces, look for the light yellow board with your AC power source. Unplug it for 30 minutes and repeat the process. while your at it, also look down to the lower left side of the monitor. u should be able to see the keypad. press each button, while pressing, look to see if the button is pressing against the circuit board. it may be loose, try this test, u just may be able to fix your keyboard as well. hope this works out.
Posted on Jan 30, 2009
  • 90 Answers
SOURCE: dell 42" plazma tv
turn the tv with the rear cover facing you. power on the tv, look into the grills on the rear cover. If you happen to see 3 green lights together on the mainboard, you have communication signal. Otherwise, its the mainboard. If u get all 3, then its your Y main board and probably a lower or upper buffer, depending on where burn is located on panel board.
Posted on Mar 24, 2009
  • 9 Answers
SOURCE: Dell W1700 no video no audio
It would probaly cost more than its worth to him to send out to get fixed. but thanks
Posted on Apr 19, 2009
How do i set my home theatre as the default speakers on my viera led/lcd tv. When i turn off the tv and my JBL SB350 soundbar it resumes to tv speakers when i turn it on again?
Page 104 of the manual. It's through the Viera link settings. I have a similar TV. It's a little convoluted.
Through Viera link you set sound selection to Home Cinema and it mutes your TV speakers when your external speakers are on. I use that now now with a similar sound box (Zvox). It works fine. That doesn't work with the playbar...
enable hotel mode by pressing, at the same time, the down volume button on the side of your tv and the 'tv' button on the remote 3 times. A menu will pop up where you can set max volume to 0.
Jan 01, 2015 | Panasonic VIERA Televison & Video
LED Hotel Mode key?
You have to enter its service mode option to turn ON of OFF and Adjust the Hotel mode options. If you wish to get more details about how to enter hotel mode, and make necessary adjustments, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. Never forget to EXIT service mode, after you've done all necessary adjustments.
Jun 28, 2013 | Televison & Video
I purchased a LG 32lx4dc tv from a hotel liquidator but i can't it to work at home? I don't have the remote. Can I access the menu using a universal remote? Will I ever get it to work at home?
Here is what worked for me:
1. On the LST-4100A box, there is a black, removable card with an F-connector (Cable In) and a RJ-11 (Data). Unscrew the two retaining screws and remove this card. There is an antenna-type connector on the inside that will need to be disconnected from the card.
2. Connnect the control box to the TV via the serial cable (Display Control).
3. Plug in power cables to TV and control box. Turn on TV.
4. There are two lights on the control box. Make sure the "Power" light is on solid and the "Status" light is flashing quickly. If not, cycle power on both the TV and the control box.
5. Press "Menu" and hold the button until the menu disappears.
6. Quickly, press "2 6 6 3" then press "Enter". A small menu should open in the upper left.
7. Scroll down to "DBox". Change to "Off". TV will restart.
8. Disconnect the serial cable from the TV. The remote controls should now work normally with the control box disconnected.
Oct 01, 2012 | LG 32LX4DC 32 in. LCD Television
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
Jan 27, 2012 | Samsung 32 UN32D4000 LCD TV
I have a Compaq Presario 700 series. About a month ago the LCD went crazy for no apparent reason and I took it in for service. They told me the LCD was bad and had to be replaced. They said it would cost...
  1. First, since this LCD your using is a TV ready you need to check if it's in the PIP mode (picture in picture). Because if its in this mode the TV screen will be divided into parts.
  2. Secondly, checked the remote then try to press the PIP mode so that your screen will back to a normal mode.
  3. If pressing the PIP button will not bring it m\back to a normal mode try to remove the connection of the TV to your LCD TV and then make sure that the LCD and the laptop is off then try to connect it again then power on both LCD tv and the laptop.
If you have further questions fell free to reply to this solution. Cheers!
Feb 10, 2011 | HP Compaq Presario C769US Notebook
Dell W3202MH LCD monitor gets power, but no image. Backlight?Power indicator light comes on, but no Dell logo or anything on the screen.
It can be bad backlight inverter board or bad power supply for the inverter. Look at the power supply first since it is easy to get too than the inverter board, look for bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. Pictures will help.
Nov 12, 2009 | Dell W3202MH 32 in. LCD Television
Hotel lock, not available but im sure there is another way
Not all sets have a hotel lock.....key in for a google search on the model and get a free download of the user manual.
May 20, 2009 | Sansui HDLCD3210 32 in. LCD TV
TV problem
take your tv to a tech your power supply is faulty or the xray protection circuit.good luck.
May 06, 2007 | Akai LCT3215/26 32 in. LCD Television
Televison & Video Logo
217 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
